SOURCE: Pilot light seems to high
there may be an adjustment screw for pilot height. you'll have to look at the valve. a pilot should have an inner cone of greenish blue color and the surrounding flame should be a deep blue no yellow or orange tips. the pilot burns pure fuel no air. the main valve does mix air with the gas in order to burn.
SOURCE: Heatilator Pilot Issue
Any pilot adjustment would be under a large screw with a flat blade slot in it. There would be a smalled flat blade screw under it. Warning: Too small of a flame and your safety device won't work.
READ MORE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: adjust pilot light
Adjust? What do you mean? The flame relationship to the T-couple? Or is the flame too low?
Low flame can be adjusted on some gas valves but mostly it requires special tools and knowledge of the gas valve. Most times it's a sign the GV is going.
SOURCE: how do i adjust oven pilot light on vulcan range
hi, there is an orfice for the oven located on the gas valve. If you are using LP gas, the orfice should be turn down all the way (counter clockwise). If you are using natural gas, the orfice should be turned out about 2-1/2 turns. Was this oven set up to be used with one gas and noe is being used with another? If so, you will need to do more then adjust orfices. Please let me know if I can assist you further.
Thaks
Vic
