20 Most Recent Dyna Glo "" Natural Gas Heater Mn200tba Questions & Answers
REMOVE GAS LINE FROM IGNIGHTER AND THERMO CUPPLING, BLOW OUT WITH AIR. RGRANT
Dyna Glo ""... | Answered on Dec 14, 2014
check your gas pressure meter might be too small call gas company they will assist you
Dyna Glo ""... | Answered on May 08, 2014
It will look like a short piece of copper tubing usually.
Dyna Glo ""... | Answered on Oct 07, 2012
Here is some of their contact info:
GHP Group, Inc. 8280 N. Austin Avenue
Morton Grove, IL 60053-3207 Phone:
Fax:
Toll-free: 1-847-324-5900
1-847-583-0890
1-877-447-4768
Email: customerservice@ghpgroupinc.com GHP Group, Inc. 8280 N. Austin Avenue
Fax:
1-847-583-0890
1-877-447-4768
Fax:
1-847-583-0890
1-877-447-4768
Fax:
1-847-583-0890
1-877-447-4768
Email: customerservice@ghpgroupinc.comjohn224_0.jpg
Or an actual link:
http://www.ghpgroupinc.com/
John
Dyna Glo ""... | Answered on Jan 23, 2011
the thermal coupler is bad. That is the piece by the pilot that has a copper line that goes to the gas valve. replace that and it should be fine. hope this helps. have a good day.
Dyna Glo ""... | Answered on Jan 13, 2011
If this aluminum tube has nuts on each end, I would bet that if you called your local plumbing supply house & described the part, they would have one in stock. Do you feel capable of removing the part?
Dyna Glo ""... | Answered on Dec 21, 2010
It may be possible, but I have never seen a conversion kit for them.
Also given that the only thing of value in one of those is the gas valve it is probably much more cost effective to just sell the one and buy the other...the difference would be the cost of the conversion kit and you have no labor involved except removal and re-installation...and that takes all of a few minutes...
heatman101
Dyna Glo ""... | Answered on Oct 13, 2010
Hmmm ... where did you buy the last one? Are they out of business?
Here is what I found when I used Google:
http://www.mytoolsbee.com/cat164509.html
Ace Hardware may be a place you can order this stove from also.
Thanks for your question at FixYa.com
Dyna Glo ""... | Answered on Feb 16, 2010
if it wil light and wont stay lit replace your thermal coupling
Dyna Glo ""... | Answered on Feb 01, 2010
The thermocouple from the burner flame port to the gas valve is bad. Shut your gas supply off, unscrew the small fitting with the small copper tubing coming out of the gas valve. Follow that tubing up to the burner and disassemble the pilot light end from the burner. Home Depot has a good selection normally or you may want to go to a furnace supply. It shouldn't be more than 10 or 15 dollars for the new one. Reinstall, turn the gas back on and make any adjustments to flame location at the burner.
Dyna Glo ""... | Answered on Jan 21, 2010
Fault in the gas supply, have serviceman check out.
Dyna Glo ""... | Answered on Jan 13, 2010
You should check the flame sensor. That is the most often culprit. Good luck...Lee
Dyna Glo ""... | Answered on Jan 04, 2010
This could be the case if you haven't used the heater for a while. You will need to close the main valve then unscrew the connection to the heater and open the valve for a few seconds till you smell gas. Close the valve and tighten the gas connection again. Leave it to air out for fifteen munites or so and try lighting again. Be sure to let the area air out as gas will explode.
Dyna Glo ""... | Answered on Dec 20, 2009
Cleaned pilot light area with an air compressor. Problem solved!
Dyna Glo ""... | Answered on Apr 16, 2009
Dyna Glo "" Natural Gas Heater  Mn200tba Logo
Popular Tags
21 questions posted
Top Dyna Glo Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Dyna Glo Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Dyna Glo Pool & Spa
  • Dyna Glo Pool & Spa
Most Popular Question
phone nunber manufacture
  • Pool & Spa
