What do you mean by irrelevant and flagged please?
My Honeywell pro series thermostat has a caution flag on the display. What does that mean?
Do you mean the alert flag (a triangle with an exclamation inside it) or a different symbol? The Alert flag will appear with another message on the screen. If it is time to replace the battery, you'll also see "BATT" to the left of the flag and a low battery icon somewhere along the top of the LCD screen. If the thermostat is set to alert you to change the HVAC system filter regularly, you'll see "REPL" to the left of the alert flag.
This is from the T4 Pro thermostat manual on pages 6 and 7. See https://forwardthinking.honeywellhome.com/assets/tseries/resources/install/T4%20Pro%20User%20Guide%20-%2033-00188EFS.pdf . The T6 Pro uses the same alert behavior.
I hope this helps.
What does australian flag mean
It has to do with their British heritage, their geologically southern location, and also the territories. The following page really describes it in great detail:
Australian Flag The Flag Meaning
Diameter is 1,88mm and thickness is 20mm. what is the mean diameter?.
It the diameter of a circular object is 1,88 mm then the mean diameter is also 1,88 mm. The thickness is irrelevant.
Sep 18, 2013 • Cameras
Does the flag of Denmark have a name?
The flag of Denmark is named Dannebrog meaning Danish cloth.
Apr 25, 2013 • Home
How do you remove a question from FixYa?
Currently you cannot delete a question of Fixya. If the problem is irrelevant or abusive you can report abuse by clicking on the flag at the top of the question page. The question will then be reviewed by the Fixya Support team. Just be sure to provide some details as to why the question should be removed.
Alternatively, you can also contact the Support Team at http://www.fixya.com/contact
Hope that helps!
I cant go on face book on my phone it says internet protocol address that as been associated wih abusive behavior something about a proxy i havent done anything and still use facebook on my laptop please...
It sounds like your phone's IP address has been flagged. Someone may have reported you for something (doesn't necessarily mean you did anything wrong). Contact Facebook and explain the situation. They can shed more light on why your phone's IP address is flagged.
I have a little red flag at the top of the screne next to the bluetooth what does that mean
i have a little red flag at th top of the screne next to the bluetooth what does that mean?
Tomtom 1 europe
Tap screen, then tap lower middle icon, tap Right Arrow seven times, tap button with country flags, choose your language...
k24674
ADMIN Andrew
ADMIN Andrew
