Lemax Village Collection Oak Creek Grist Mill 2pc Set With 9v Adaptor Logo
Tom Smart Posted on Dec 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Cosmic Swing has stopped rotating. The seats still extend outward OK when turned on. I can hear the motor operating.
David Ellis Rhea
Level 3:
  • Master 3,462 Answers
  • Posted on Dec 22, 2017
David Ellis Rhea
Master
Level 3:
Answers
3462
Questions
Helped
786310
Points
10903
I think I am not familiar with a Cosmic Swing car or truck.
Please share the year, make, model, and mileage of your vehicle.
2answers
Asko T701 stopped running.
Test the wirings to control panel and the switch.
Try also a different outlet, and eventually check with a tester the power cord.
Also the switch must be tested.
If the wirings are ok then the whole control panel can be replaced.
If you want to buy parts you find them here.
Turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier http://advancecamera.com/repair
3answers
Driver side electric seat is stuck in the far forward position and won't move. How do I move it manually or fix the motor.
Auto Repair: How to Replace a Power Seat Motor - YouTube
? 1:44
https://www.youtube.com/watch?v=EDh-0rs5Fjo
Oct 26, 2010 - Uploaded by automdvideos
Auto Repair: How to Replace a Power Seat Motor ... 2007 - 2008 Ford Expedition/Lincoln Navigator Driver Bottom Install Video ...2003-2006 Chevy/GMC Seat Cover Install 1 of 3 - eBay Ready ...2000 Ford Explorer Front Seat Track Stuck Motor Repair - Duration: 4:39. by cubmancan 4,959 views. 4:39.
Drivers seat is dead! No power seat or heat. - TheDieselGarage.comwww.thedieselgarage.com/.../96465-drivers-seat-dead-no-power-seat-hea...Mar 22, 2010 - 2003-2005 Chevrolet Avalanche, Silverado, Suburban, Tahoe 2003-2005.... Power seat on driver side didn't work.....passenger did! Neither ...DANG electric seat ' Chevy Truck Forum ' GM Truck Clubwww.gmtruckclub.com/forum/threads/dang-electric-seat.2990/Apr 27, 2006 - 10 posts - ‎7 authors'03 Tahoe My driver seat just stopped, of corse not where I need it, the ... I have a 2003Tahoe and both heated seats are not working. ... with my seat heater on the drivers seat in my 03 Avalanche, it turns ... The driver's side on my Silverado gets way warmer than the passenger side. ... Frozen New Member.Power Seat Problems?? - Tahoe Forum - Che
1helpful
2answers
Washing machine stopped spinning & tumbling at any cycle. Have limited knowledge on multimeter use, but door lock/switch appears to be in working order. Belt around motor in excellent condition. ...
Check the condition of brushes. Replace if necessary. Check motor rotation. Not rotating, check if it has a soft starter for motor. If there is soft starter, bypass it. Check the motor rotation. If it does not rotate, then it is quite likely that the motor is burnt.
- sonsunny
The motor for the lumbar support for the back of the driver's seat operates in only one direction. In the back of the seat, you can hear a very soft click when you release the switch, but the adjusting...
the problem can be that the gear wheel can be strip on one spot ,and if the gear is plastic,and because of the back being more heavy it puts more strain on the gear and some times one can rush and push the back by hand ,all this can cause the gear to
strip.
1helpful
Fisher price precious planet swing front to back motion?
All you need to do is rotate the seat. You have to just grab the seat and turn it your self the pole doesn't move but the seat itself does.
My Fisher Price Precious Planet Swing tilts to the side.
the seat itself should rotate around even though the bar is in front to back the seat can be in forward or sideways position
Apr 07, 2009 • Baby Gear
Top Lemax Toys Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Lemax Toy Expert? Answer questions, earn points and help others
