Computers & Internet Logo
c
chuck hills Posted on Dec 14, 2017
A GRAY AND SMALLER BLUE MENU SCREEN KEEPS POPPING UP AND CANT DO A THING WITH IT .
  • Anthony Cardenas
    Anthony Cardenas Dec 15, 2017
    Hi chuck hills, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
5 Related Answers
Paul
  • 225 Answers
  • Posted on Oct 01, 2008
SOURCE: menu screen
It could be dirt/dust has accumulated behind the buttons causing a false contact so it looks like a ghost is operating your tv making things appear and disappear.If this isn not the problem then there is a faulty component on the board where the buttons are located. If you are able to do the cleaning of the buttons yourself use a cleaner that de-greases as wel and make sure everything is bone dry before re-assembly. If not find a competant technician. Hope this helps.
Anonymous
  • Posted on Mar 05, 2009
SOURCE: Menu Screen keeps popping up
WHAT BRAND AND MODEL NUMBER?
ultimitloozr
  • 489 Answers
  • Posted on Jun 01, 2009
SOURCE: menu screen keeps popping on and off during usage
Check the menu button on your monitor. Chances are it is stuck in the depressed position. (Sometimes an edge of the button will get caught beneath the frame.)
Anonymous
  • 63 Answers
  • Posted on Dec 16, 2009
SOURCE: THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
Anonymous
  • 182 Answers
  • Posted on Aug 31, 2011
SOURCE: my monitor menu on my samsung syncmaster 731n
this is a normal condition for that kind of monitor, because it was design only with Samsung syncmaster 731n in which the old model. The reason why it always popping up is because it always adjust the setting of the images. The only way to solve this problem is if this menu appears again you only press the reset button there at the left side of the power button.
1helpful
2answers
On my technika TV menu screen keeps popping up,how can i stop this?
problem seems to be solved,i altered the auto time feature and it settled down
thanks for replying
Bob Hawksby
Menu keeps popping up
Make a hard reset to this set and try.
2answers
Crt monitor turned orange and the monitor menu keeps popping up
probably its old or try to check the color status in display property in desktop properties
Menu screen keeps popping up cant turn it off RCA r52wh74
On your front panel board where you press on/off ch+ch- vol-vol+ the Menu contact switch is either dirty or defective,Clean all front contact swiches or replace them Clean with contact cleaner only for Parts Call Mats 1-800-628-1118 This another problem RCA has with these TVs.
1helpful
Menu screen keeps popping on and off during usage
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Top Blue Computers & Internet Experts
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
vince
Are you a Blue Computer and Internet Expert? Answer questions, earn points and help others
