SOURCE: Lower Blade Guard on a Miter saw
If you haven't fixed them yet, give me the model and brand and I will see what I can do. Dave
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
SOURCE: How to replace Ryobi circular saw CSB140LZ lower guard assembly
Clean the area where the guard attaches to the hub assy. It is a snap ring that is holding the guard on. You will need to either use a pick or a small flathead screw driver in order to remove it. There should be a little tab that you will be able to work out. Look around the entire perimeter of the hub to locate it. You may need some extra light to see it. Stick the pick or small flathead behind the tab from the right. Work the tab out and above the hub. Now you can work your pick or scredriver around the perimeter to remove the ring. Install it in a similar fashion but use the flathead to guide the ring back into the groove, working it around the opposite way.
Testimonial: "Got it. Thanks"
SOURCE: replacing the blade guard spring
there is a hold in the lower guard for the loop and the other end wraps around the guard slightly and there is a hole in the back of the upper guard. You can go to Milwaukeetool.com and download a breakdown for the tool Also when you have the blade off I would try using compressed air to clean the area and spray some lubricant on the hub to lubricate. The guard should "snap" back when done sawing. Let me know if you need more help
SOURCE: how to replace saw blade and re assemble the blade
Hello. The guard does not have to be taken apart when changing the blade. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
