SOURCE: Humax Tivo will not record to DVD
After the update to 1.15 I had to delete EVERY recording on the unit. After that, any new recordings would burn just fine. However, some have found that same failure even after a hard reboot (repower). Called Humax level-1 support and they suggested a replacement unit so I swapped it out. But I've since learned that TiVo "pushes" a DVD firmware patch (possible supplied by Humax) from 1.08 to 1.15 and that patch is the culprit. That patch is suppose to make the DVD burn at a higher spin rate. After talking with level-2 Humax support they heard of the problem and said "the unit is working as designed", meaning, the DVD drive manufacturer specs say the drive is capable of a faster burn rate. So now I have Humax DTR800 #2 and so-far-so-good, but TiVo hasn't pushed the patch onto the box yet!
SOURCE: record and watch different channels with freesat
I believe that the Humax can only output 1 channel and because it has no built in hdd and twin channel capabilty that is all you can record 1 channel (unlike sky +/sky HD) so that means also that unless you watch a different source (like the picture from your aerial (terrestial channels)) you are stuck with having to watch the channel you record
SOURCE: No colour when I record using the Dazzle DVD Recorder.
Get a program called amcap and you also need pinnacle studio first open pinnacle studio then go to capture then if your using 12 dv then open amcap an error will come up then go to options then video filter settings or something then where it says pal or ntsc change it to secam b then go to pinnacle studio and look at the preview, it is in color then when you start recording it goes black and white again so open amcap go to options then video capture filter then change secam to ntsc then apply then go to secam b again then it will be recording in color then you have to cut out the black and white in pinnacle studio or any other video editing program I use sony vegas pro 9 then search tutorials on the program but it is easy in any program really.
SOURCE: I ws using my humax to watch a programme, when the picture froze.
It can sometimes happen if the signal level drops & the TV digital decoder cannot pick up the strength of the signal when the transmission is back to normal. Switching on & off again resets the processing again. This is a similar effect that can happen with cable or sky transmissions also, it acts the smae way as sometimes having to re-boot your PC if that should crash. It is not necessarily a fault with the TV.
Testimonial: "Sounds logical, but why did not the TV digital signal also crash? "
SOURCE: humax digital recorder picture freeze every 10 minutes
Humax are having problems and are starting to send out software upgrades (night-time updates) - seems to be related to the new formats on the MUXs for the digital switch-over. Our 9150T hasn't been fixed yet but due any day (I hope)
