20 Most Recent Humax PVR9300T HD DVR Questions & Answers
If you can see the infrared signal on the remote with a camera, the issue is most likely not the remote. That unit is about 8 years old and has most likely gone to dvr graveyard. You cannot get parts for it that would be easy to change.
Humax PVR9300T... | Answered on Oct 07, 2016
576p means 576 lines, progressive scan. 576 is number of visible lines on the UK system (and other nominally 625 line countries). The normal transmission system for these countries is 576i (interlaced scan), so I suspect that you are only seeing the 576p indication because there are no channels, and your TV is interpreting this as progressive scan.
The reason for no channels may be a poor signal from the aerial, or that the device (Humax or TV) has not been tuned. If you have power-saving enabled on the Humax, it will not pass on the aerial signal to the TV when the Humax is in standby. If this is the case, either turn power-saving off, or use a splitter to feed the aerial separately to the TV and Humax.
Humax PVR9300T... | Answered on Mar 10, 2016
If you have added padding to the start and/or end of the recordings, this will disable series record.
In the Record Menu, set Start and End times to On Time if you want to use Series Record.
Humax PVR9300T... | Answered on Feb 17, 2016
Find the next event to be recorded in the Guide, press the record button and it will give you the option to cancel a single recording or the whole series.
Yes, you can connect your Humax to a TV while away from home.
First thing to try is the batteries in the remote. Use new fresh ones, the second this is to see if it is a radio or light controlled remote. If it is radio then you have something causing interference. If it is light control then the remote is probably bad. There are parts in the remote that don't survive falls in some cases
Humax PVR9300T... | Answered on Jan 16, 2016
No, it can only record from its own tuners via an aerial, not from a scart connection..
Humax PVR9300T... | Answered on Aug 20, 2015
Try a factory reset. If that doesn't fix it, it may need some PSU capacitors replacing.
Can you replay previous recordings?
Humax PVR9300T... | Answered on Apr 28, 2015
I've got one. Does exactly the same thing. It usually happens within the first, say, 10 hours of recorded material. This is the most used part of the hard drive disc. We have 5-9 hours of programs we intend to keep so we end up re-recording over the next part of the disc repeatedly. This wears that part down. What I did was keep 2-3 hours of stuff in that zone and carried on recording and deleting as usual, as I still do. I'm watching it right now. But if I erase past the break 'zone', the recordings 'jump'. It has a big memory and shouldn't be a problem. So..........fill with programs to half the disc and record over the lesser used part of the disc.....it works for me. I'd be interested in hearing how you get on. Good luck Red.
Humax PVR9300T... | Answered on Mar 04, 2015
Depending on its age, this model is known to need its PSU capacitors replacing eventually. This should not be an expensive job.
Humax PVR9300T... | Answered on Jan 08, 2015
It means that 'Antenna Power' in the Installation menu is switched on when it should be off. This is only required when sending power to a mast-head amplifier.
From the Programme Guide select the programme you want and press OK. Then select the 'Record the Series' option. Note that this option will not appear for one-off programmes such as films.
You are going to need to have your aerial adjusted, it's getting conflicting signals. I have a Humax in London, not until recently was this sorted out by repositioning the aerial to the strongest signal.
Humax PVR9300T HD DVR Logo
56 questions posted
Top Humax Televison & Video Experts
 Grubhead
Grubhead
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Humax Televison & Video
Most Popular Question
find out box or remote when not talking
  • Televison & Video
