Not 100 % sure but on my dvr that is auto record. if you right click and go to record and then click in each frame of in the selection box you can get them to do a manual record. than it changes to a dark color. i checked mine and they are all blue and they are recording in auto mode and they loop when the drive gets full.
Testimonial: "Thanks for the advice i will try this tonight"
SOURCE: linking cctv cameras over linksys router, ports
What is the problem exactly ?
For port list try this link :
http://linksysfirmwares.googlepages.com/portslist
Hope it helps
SOURCE: cctv remote view/ adtran total access 900e
It's not likely that VZ gave you dynamic IP's, but it's possible. You should have been given more than one. If not, it's better to get more and a set of configuration instructions. In the last one I set up, we put a 5-port switch on the ethernet port coming off the Adtran, then fed 2 routers and a security system from the switch. Our gateway was one number lower than the bank of IP's we had, and we just gave each piece of equipment a static ip address and gateway to the gateway :-)
Carl
SOURCE: cctv wavy lines from camera
often problems with lines is either down to RF or if all the cameras are powered of the same psu that it could be that your psu is underated and the cameras are pulling to many amps most moden cameras rum anything from 200mas upto 1.5amps with infra red so if you only have a 500ma psu its going give up slowely
SOURCE: how to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
SOURCE: how to control panasonic wv-cw960 through controller wv-cu161
how do i control my speed dome cam wb cw 960 connected to wj rt 416v, now that i dont have wv p416e 4 channel card in the market. i need to add rs485 cable but is there a connection port or do i need to add a hub i am talking about adding 3 units 960 units. pls advice.
