SOURCE: Sega Game Gear
try adjusting the brightness knob on the system. i once had that same problem with mine. The ccfl tube (the main battery drain problem in most portables) might be burnt out or something. You can replace it with LED's i think.
SOURCE: my sega game gear sound has no sound how can i fix it!
might need a new headphone jack due to rough handling or a new volume pot. try plugging in headphones and wriggling them gently to see if you get sound, if that does not work try fiddling the volume knob, whichever gives a burst of sound will show you which needs to be replaced.
SOURCE: Sega game gear turns on but the screen is black with a few grey lines
i think that means the cable from the sega to the t.v is faulty or loose try riggling it around if its not that try a different channel
