I click camera, But no images on screen. just a black screen and a button for taking pics, but no images.
SOURCE: black screen cant take photos
I had this problem today with my S1 IS. I did a google search for similar symptoms and found that many digital camera models made between 2002 and 2004 have a CCD issue. I called Canon's Customer Support (1-800-828-4040) and they offered to fix the problem for free. Hope this helps!
SOURCE: black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
I had the same problem with my CoolPix5400 and this resolved the issue.
SOURCE: camra dosent show pic
Please see similar problem titled "black screen". Welsbar posted a possible solution as a clarification request. It involves switching your picture mode to TV and changing the shutter speed to 15 seconds, depressing the shutter button for 7 seconds, then opening battery enclosure. Repeat as necessary - I did this twice before I started to see anything on the screen. Twice more before photos start to look okay. Don't know yet if this is a lasting solution, but at least now I can start using the camera again and find out!
According to Welsbar, the problem is an internal part (iris?) that gets stuck when camera hasn't been used frequently.
SOURCE: black screen wont show images
May be the issue with CCD (image sensor device) of the Camera.
Refer this article to cofirm this.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Check whether the LCD screen of the Camera looks similar as given on the page.
If yes, click on the "Yes" button at the end of the page to create an online Repair Request for sending the Camera to the Sony Factory Service Center.
SOURCE: Camera not displaying images as seen through
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and
flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Have you put a film in it ?
