Coffee Makers & Espresso Machines Logo
Lucie Allaire Posted on Sep 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bodum cone coffee grinder motor runs but does not grind the coffee beans, seems like it is not turning, what could it be?
  • Max Muller May 19, 2020
    try to buy a new one
Mikey
Level 3:
Top Expert:
  • Bodum Master 6,904 Answers
  • Posted on May 19, 2020
 Mikey
Bodum Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1623686
Points
26106
5 Related Answers
Anonymous
  • Posted on Dec 28, 2008
SOURCE: Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Anonymous
  • Posted on Apr 12, 2009
SOURCE: grinder does not work!
http://www.cerinicoffee.com/custompages/Tech/Grinder_Adjustments_for_Italia.pdf
Anonymous
  • Posted on Aug 14, 2009
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
graybeard32301
  • 382 Answers
  • Posted on Dec 01, 2009
SOURCE: the grinder runs but does not grind the coffee
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Anonymous
  • 1089 Answers
  • Posted on Jan 25, 2010
SOURCE: the coffee grinder on my Magic Comfort Plus is not
Hi Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute. Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Miele CVA 4085, the grinder is not grinding the beans. It makes the noise but basically water just comes out with very little coffee.
Here are some specific steps you can take to try to repair the grinder issue with your Miele CVA 4085 coffee machine:
  1. Clean the grinder: Remove any coffee grounds that may have accumulated in the grinder mechanism, and clean it thoroughly with a brush or cloth.
  2. Check the grind burrs: Inspect the grind burrs for any signs of wear or damage, such as chips or cracks. If they are worn, they may need to be replaced.
  3. Adjust the grind setting: Make sure that the grind setting is adjusted correctly for your type of coffee beans. If it is set too fine, the grinder may struggle to process the beans.
  4. Check the grinder motor: Make sure that the grinder motor is functioning properly and that it is not overheating. If it is making a strange noise or if it seems to be struggling to turn, it may need to be repaired or replaced.
  5. Reassemble the grinder: Make sure that the grinder mechanism is properly assembled and that all components are securely fastened.
If these steps do not resolve the issue, it may be necessary to have a professional service the machine.
Regenerate response
1helpful
My bodum burr grinder stopped while grinding beans. It will not run at all.
If all the above except some lame answer about using "rice" doesn't solve your problem, then the THERMAL FUSE will have to be replaced, and it is very easy and cheap to do so, especially if you do it yourself. A THERMAL FUSE will shut down everything so that if for any reason the machine overheats, it won't burn up the motor.
1helpful
How to fix a bodum bistro electric coffee grinder that doesn't grind well
This can be caused by several things;
If it used to be good but is now faulty it is most likely that it just needs cleaning. If you are using beans that are 'oily' they can clog the grinder, you should anyway disassemble it and clean every year. Do not use soap and water, just brush it with a stiff brush (e.g. the stiffest type of toothbrush) and a vacuum cleaner.
There is also a possibility that something has got into the grinder along with the coffee beans that has damaged the grinding wheels; in that case you need to replace the wheels.
Grinder does not grind coffee properly
sounds like the motor is loosing efficiency,,,I.E. motor going out.
1helpful
Coffee grinder is not grinding beans fine enough
Try it with less beans, or the motor is not running at full speed, no other fix
Myu Bodum Bistro burr grinder calibration is off. How do I fix it?
Did you ever find a solution? I have the same grinder and it is off as well now after taking it apart.
3helpful
Have a grinder and it is full of coffee and stuck. It seems the beans were more oily and now I am trying to figure out how to clean it out. Please help
  • Try to grind all the beans through.
  • Put some uncooked rice inside the hopper and grind it, it is very good at cleaning if you don't have Grindz. Get Grindz if you can to grind and clean the burrs.
  • Try to take the grinder apart and brush off and clean off the burrs by hand.
8helpful
2answers
My A-9 Coffee grinder no longer grinds coffee. Have cleaned it and checked it out and nothing. The motor runs but no grounds. Thanks for your help!
2answers
Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Top Bodum Coffee Makers & Espresso Machines Experts
ADMIN Andrew
ADMIN Andrew
Kolbrun...
ADMIN Eric
ADMIN Eric
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
