Hi, Sound like a wire has come loose behind the dashboard, requires taking the dashboard out very carefully & re-solder the cable back one there are lots of wires behind the dashboard so if you don't think you can do this take to a vehicle electrics place or person. Hope this helps give me feedback please. Thanks, Malcolm Campbell.
SOURCE: passenger seat heater not working in my 2003 volkswagen jetta
There are different fuses. check your fuses properly.
rate this fixya
SOURCE: Renault Clio dashboard and side light blow fuse??
I found a solution to my problem on the Internet and it worked a treat
My problem was that the dashboard and both rear lights would not turn on, but the fuses were okay and nothing had been changed
It turns out that in the passenger footwell there are a few relays right in the footwell where a person would put their feet. At first it was suggested that you push your feet really hard against the front of the footwell to see if that helps, and it did, but the lights went out again later. So it was then suggested that you look for a loose relay box where the feet go (on the left hand side at the top of the footwell, nearish to the bonnet release catch). It turns out there are 2or3 relay boxes there. SImply push each one to ensure that it is correctly seated, and voila the lights work perfectly again.
A simple fix that costs nothing, saves a potentially costly visit to a garage, and can be undertaked without any tools are even needing to open the bonnet.
May not solve the problems of those blowing fuses etc, but certainly worked a treat for me
SOURCE: need to remove fuse box in 2000 ford galaxy
I do not have a manual for this car, so here is a general idea. Look at fuse box carefully to see how it it attached. There could be some screws or there could be a release lever. Keep me updated.
SOURCE: 2003 Jetta TDI alternator light came on in dash
Your voltage regulator supplies the path for the control lead of the alternator and varies the amount of current available to provide the magnetic field of the armature with the required strength.
Measuring from this lead to ground won't show much voltage.
Apparently the regulator is not integrated into the alternator and is probably failed.
If you can chase the control lead backward, you will find the regulator and these are mostly mounted on the fender well or firewall.
SOURCE: high beam lights are not working from switch.Only
check the headlight relay as this is what actually awitches the high and low beam circuits
