It means that you need to delete some files to free up some space in your internal memory storage or add a memory card to expand it. Also, if you add a memory card, you may need to go into your setting and change the default place it saves files to so that it saves to the memory card and not your camera's internal storage.
Hope this helps. Good luck!
SOURCE: new memory card says memory card full
The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
SOURCE: Camera does not read SD Memory Card
thank you so much this worked great it solved my problem thanks.
SOURCE: every time i take a picture on my camera it says
Try this...go into the menu and scroll to "reset"...follow the on-screen instructions. Then, without a card in the camera, go into the menu and scroll to "format"...follow the on-screen instructions. Then if the pics on your memory card are safely on your computer (use a card reader to do this if necessary) insert the card into the camera, go into the menu and scroll to "format" and follow the on-screen instructions. After all this, you should be ok.
SOURCE: Samsung TL220 storage issue
If you format the camera without the memory card inserted, the internal memory should be erased. Then, making sure the slide switch on the side of the card is in the unlocked position, insert the card and format it. Things should work after that. If they still don't, go into the camera menu and find "reset"...follow the on-screen instructions.
