SOURCE: 4350 Small Network Access Point's web-based configuration tool
If it is trying to connect to the internet when trying to get to the tool, you have to get a direct link to the tool. You might find this on a forum somewhere. It might also help to update your firmware, this may solve your problem immediately. The only problem with routers is that they are built to connect to the internet.If you don't have the internet it is a tedious job to get access to your access points settings. Just get the link to the page and you should be able to change your settings then.
SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
SOURCE: Dial not moving/not cycling through
If the dial won't rotate then you need to replace the timer.
SOURCE: I am getting feedback with Plantronics CS70 Wireless Headset
Echo is usually caused by the transmit (speak) level on the unit being
set too high.
1. First, try lowering the volume of the telephone. If you
still hear an echo, adjust the volume of the headset itself.
2. The master
transmit controls of the headset are the ABCD switch settings on the
bottom of the base. A is the lowest and D is the highest setting.
3. You
can fine tune this setting with the plus (+) and minus (-) buttons on
the back of the charging base.
4. If this doesn't fix the echo, try moving
the configuration dial on the left side of the charging base. The
recommended setting for most phones is 1.
SOURCE: Logitech controller incompatible
go to logitech profiler> right stick X-axis>axis properties>map to x-axis drop down menu pick mouse x-axis then repaet the step for the y-Axis.
