Plantronics CS55. When using the wireless headset the other person on the phone hears an echo of themself. This happens all the time. I tried turning the adjustment knobs unitl it stops echoing but it soon returns. How do I correct this problem?
Echo is usually caused by the transmit (speak) level on the unit being
set too high.
1. First, try lowering the volume of the telephone. If you
still hear an echo, adjust the volume of the headset itself.
2. The master
transmit controls of the headset are the ABCD switch settings on the
bottom of the base. A is the lowest and D is the highest setting.
3. You
can fine tune this setting with the plus (+) and minus (-) buttons on
the back of the charging base.
4. If this doesn't fix the echo, try moving
the configuration dial on the left side of the charging base. The
recommended setting for most phones is 1.
