SOURCE: RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
SOURCE: insignia digital tv converter/indoor antenna no signal
I had the same problem but realized that when it said NO SIGNAL,,,,it just ment for that station,,,,,switch channels and they will start to come in,,,
Good Luck,
charh20
SOURCE: Toshiba 36
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
SOURCE: what type of indoor antenna work best with this unit?cobytv/tf-tv
A simple pair of rabbit ears (standard dipole antenna) should do the trick. You will have to set the source input to NTSC/ATSC and connect the antenna to either the analog or digital F- connector inputs if you use a RF splitter you can use one anatenna for both inputs. In any event try this first.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
SOURCE: Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
