SOURCE: radio code
More than likely, you need the model and serial off the radio itself. Call Nissan, pretend ur calling from a local stero shop to request code... worked for me...
SOURCE: no code for astra (53 plate) radio cassette
First make sure that the code has not been noted somewhere
within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be
removed from the dashboard (and if you are lucky, someone may have written the
code on the casing ) .
If not then POST A BRAND NEW QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on
ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the
Serial Number
Otherwise try your Main Dealer ...........or take it into a
Decode Service who will plug in a laptop to read/recode the memory chip
(EEPROM). This takes a few minutes and shouldn`t be too expensive
SOURCE: switched radio cd cassett from
You need the radio unlock code witch presents thieves from jacking your radio
SOURCE: ive just brought a berlingo multi space on s plate
You will need to remove the radio from the dash to find the serial number on a label at the back. There is no master code for these radios - they can only be decoded from the serial number.
When you have the details go to this site and send them all numbers you find on the label including any part numbers. They will email the code right back to you for a small fee - £4.99 for Citroens.
Hope it helps.
Thanks for using FixYa
I found a very precise chart that lists all the codes.
