ERROR
CODE # 7
E7-
1) Alternative Elevation Motor
1)Cause:
Elevation Motor not moving Solution:Check
Elevation Motor connection
2)Cause:
Elevation Elevation Motor screw binding Solution:
Clean screw and lubricate
3)Cause:
Elevation Motor Motor out of Range Solution:
Check motor out of elevation
4)Cause:
E-Motor Potentiometer: Solution:
Replace Elevation Motor
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
On/Off switch Solution:
Test unit is turned on b)Cause:
Insufficient Power Source Solution:
Plug
dedicated120V, 20Amp Outlet
c)
Cause:
Line
Cord Damaged Solution:
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
Plug
c)
Cause:
Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
see the 2 alternatives. and proceed for fix it. God bless you
ERROR
CODE # 7
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
Plug
c)
Cause:
Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
ERROR
CODE # 7
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
Plug
c)
Cause:
Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up: a)Cause:
Plug
c)
Cause: Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
God bless you
ERROR
CODE # 7
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Plug
c)
Cause: Line
Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
