Z
Zaman Srg Posted on Jul 27, 2017
How to clear Code H4-00 - Office Equipment & Supplies
Clearing check engine code, service engine soon codes on 2003 buick regal
Are you asking how to clear the check engine light?
Buy a cheap code reader ( $20 ) plug it in the OBD2 port which has to be no more than 3 feet from the steering column and clear the code(s).
If the check engine light comes right back on after you have cleared the code(s),read the code(s) and correct the problem(s).
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Whats the difference between a current code and a pending code?
Pending codes and current codes are basically the same. Pending codes are for a problem that is still indicated to be a problem,but hasn't been cleared. Current codes are codes that are indicated for the current drive cycle. Usually will both be the same code if problem still exists and hasn't been cleared without repair.
How do I reset the computer system on a 2006 Ford Explorer
Are you asking how to reset the computer or how to clear an error code/check engine light? Clearing a check engine light (which will also clear the error code) can be done with a code scanner. These are usually available for use at little or no cost at any larger auto parts store (they may even connect the scanner for you and record/clear the code). One word of caution, however: if you clear the code but don't repair the cause, the code and light will return after a brief amount of time. Now as for resetting the computer itself, not recommended that you try since error codes are stored in non-volatile memory. Disconnecting the battery's positive terminal for an hour or so may clear the check engine light, but, again, it will reappear and regenerate the error code unless the cause is fixed. Good luck.
1helpful
2answers
How do i clear a code
A lot of times a code can be cleared by simply disconnecting the negative battery cable for about ten minutes then reconnecting. If the code goes away then comes back later you probably have a defective component or sensor. If the code doesnt go away you definitely have a bad component. A dealer might tell you what the code means. If you buy a Haynes or other after market service manual it may show the code and the repair.
6helpful
3answers
I have a motorolla ming... i dont know the code for the master reset / master clear / its asking for a 6 digit code / i do see only in the manual a 4 digit code
You have the option of using Master Reset or Master Clear to reset settings, and remove information.
Master Reset resets all settings on device to factory default.
Master Clear resets all settings to factory default, plus clears all data from the device including: PIM data, Call History, Settings, etc.
To perform a Master Reset or Master Clear:
  1. Press Start.
  2. Scroll to and select System Tools.
  3. Scroll to and select either Master Reset or Master Clear.
  4. Press Yes when Alert appears.
  5. Enter Master Code (normally 000000).
10helpful
2answers
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
2answers
Error code M1 appears and how to clear it . M2 is ok easy to clear.
How to clear an M1 code.
Solution:
To clear an M1 code, go to Counter/Maintenance/Maintenance Set and press the Clear key.
hope that help
k24674
ADMIN Andrew
ADMIN Andrew
