Cars & Trucks Logo
Luis Ramrez Posted on Jun 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2000 ford f series wiring diagram
Hi, i need to fix my fuel gauge on my 2000 f250 5.4 [modified to tow truck] have no wiring harness from fuel pump to dash....i hope can understand my problem thanks
Kulu Criss
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 82 Answers
  • Posted on Jun 12, 2017
Kulu Criss
Expert
Level 2:
New Friend:
Cheetah:
Answers
82
Questions
Helped
24158
Points
231
Https://www.ford-trucks.com/forums/1085644-exploded-view-wiring-diagram-etc.html
How do you wire a replacement fuel pump into a 1999 Ford Ranger that has a wire for a flexfuel sensor on the truck harness, but not on the replacement fuel pump?
Before you begin, it is important to note that modifying electrical systems in a vehicle can be dangerous, and it is always best to consult with a professional mechanic or electrician before attempting any repairs.
That being said, here are the general steps for wiring a replacement fuel pump into a 1999 Ford Ranger that has a wire for a flexfuel sensor on the truck harness, but not on the replacement fuel pump:
  1. Locate the fuel pump relay in the power distribution box under the hood of your Ford Ranger. The fuel pump relay is usually marked on the cover of the box.
  2. Remove the fuel pump relay and identify the two pins that connect to the fuel pump.
  3. Connect a wire to each of these two pins on the fuel pump relay.
  4. Connect the other end of these two wires to the corresponding wires on the replacement fuel pump. Typically, one wire will be for the power supply, and the other will be for the ground connection.
  5. Locate the wire for the flexfuel sensor on the truck harness. This wire will be a different color than the wires for the fuel pump.
  6. Cut the wire for the flexfuel sensor, leaving enough room to splice in a new wire.
  7. Strip the insulation from the ends of the cut wire and the new wire that you will use to connect the fuel pump.
  8. Twist the bare ends of the two wires together and secure them with a wire connector or solder.
  9. Connect the other end of the new wire to the appropriate terminal on the fuel pump.
  10. Test the fuel pump to make sure it is functioning properly before starting the engine.
It is important to note that the exact process for wiring a replacement fuel pump can vary depending on the make and model of the vehicle, as well as the specific replacement part being installed. Therefore, it is always best to consult the manufacturer's instructions and wiring diagrams, or seek the advice of a professional mechanic, before attempting any repairs.
Gas gauge staying at empty when tank is full
Spencer, Check all fuses ,plugs and grounding at the tank.The sending unit module, inside the GM's gas tanks were notorious for going bad in this err, when you changed it did you use a quality part? Also the fuel pump sending unit plug/wire harnesses were known issues, so much that replacement pumps would often come with replacement plug to splice into existing harness. Check the attached links,instruction and guides on how to trouble shoot fuel gauge/sending unit, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
General Motors Fuel Gauge Troubleshooting American Autowire
GM Defective Gas Gauge Leaves Owners Guessing
Fuel Gauge Tech How To Properly Diagnose Faulty Fuel Pump Sending Unit
GM Fuel Pump Level Sensor Diagnosis Testing
Fuel gauge wiring diagram
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
What is mirror wiring for plugins?
Installing 08 mirrors on 01 Superduty, looking for wiring diagrams ...
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Aug 12, 2008 - Installing 08 mirrors on 01 Superduty, looking for wiring diagrams Super Duty ... 2013-2014 mirror plug pin outs, SUPERDUTY_08, Super Duty ... Power/Heated/Lighted Tow Mirror upgrade...
Jul 24, 2012
F250 Paddle to towing mirror installation
Dec 20, 2010
Towing Mirror Wiring Harness Adaptor
Sep 15, 2010
Towing mirrors
Apr 16, 2010
More results from www.ford-trucks.com
Needing color coded wiring schematic for junction of fuel pump and fuel level float inside gas tank
They are 2 ways to get this. An internet search using your year make and model car with the term fuel pump wiring or wiring diagram usually pulls up a collage of good diagrams. Or the autozone site has a help site at the bottom of its help page, There is a free part and a pay part, but free info will supply diagrams.
2helpful
My aunts 1997 Jimmy was towed to my Dads .Cranks but no start,after batt. charged. They had been hitting bottom of fuel tank,and would start.But not anymore . Dad replaced pump.Had to rewire connectors for...
I would recommend checking the "re-wire job and make sure it is done correctly. Many GMs have had problems with the connectors at the fuel pumps. The fuel pump manufacturers have re-designed the connector to correct the problems they have been having. This is WHY the re-wire is required. The fuel pump kits usually come with the new connector to complete the job. However, some of the kits have wire colors that do not match the wire colors on the vehicle harness, Some of them also have "duplicate" colors, like two black wires. One will be a larger gauge than the other one. I had a couple where the white wire on the new connector had to be wired to the purple wire on the vehicle harness, etc. If your dad did not follow the directions EXACTLY then this could be the cause of your problem. (The pump MAY be running backwards)
1helpful
New fuel pump and sending unit. now gas gauge
if the gas gauge worked before i would just double check the connections to the fuel pump and make sure they are tight.
Need control circuit wiring diagram fuse,relay(s) for fuel pump.
See page one at the pdf link below.
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=18451
2000 chevy blazer fuel gauge
did you recently change the fuel pump? If so you needed to change the wire harness thats attached to the fuel pump, then if not, your floater need to be replaced inside your fuel tank.
How do I know? from experience.
1helpful
Electric fuel pump wiring harness diagram
Your best bet is to type it in to autozone.com and got to the repair section. it will tell you there.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
