SOURCE: Needle won't move
Make sure the clutch motor is powering up. make sure voltage toggle switch is on 110v and not 220v. Also rotation set correctly. Independently, make sure the motor runs. With your hands and motor belt disengaged, attempt to turn the handwheel toward you. If it is moving, then make sure motor is running. It handwheel does not turn it could be the machine. Make sure the stitch length dial is set at 2 or 3 and not 0 or 5. That could be that problem as well.
SOURCE: I do not have my SINGER sewing machine on me at
Alot of Singer manuals are available for download from their website (must know the model number):
http://www.singerco.com/accessories/manuals.html
SOURCE: I need a manual for
Hi Hilary, there are many Singer MCPK machine. More than the serial number you will need a model number to enter here.
If the service tag with model number has been removed, try identifying model here.
Try also checking the manual for MCPK 5808: Download the complete user guide (705 Ko)
SOURCE: I just recently purchased a Singer "Brilliance"
Go to www.singerco.com and under customer support, you will see instruction manuals, now enter 6180 in the box, and voila, a free copy of your manual to download.
