SOURCE: Bios Reset
thereis a switch to remove bios password on the motherboard
http://slanyfree.net/howto.php?file=%2FHardware%2Facer-240-reset-password this is where it is and how to get to it
just move the first switch over and that will remove the pw
SOURCE: ihave a kyocera phantom cell phone i cant remember unlock code
go to nearest kyocera service center and unlock
SOURCE: I cant remember my security pin on my samsung g600
PIN CODE is SIM dependenet and not phone dependent
PUK code in PIN UNLOCKING CODE, which is required when you give PIN number wrongly for 3 times,
This code is OPERATOR specific and not phone specific and you have to call you operator and get PUK if PIN is blocked...
if you provide PUK code wrongly for 7 time, you sim may become useless, then you have to buy new SIM
NOTE: You should ask your service provider,get the PUK, give the PIN 3 times wrongly and it asks for PUk,provide the PUK and set the new PIN..
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
SOURCE: I forgot my pin code for my cell phone
contact your service provider, they will help you reset your password for you.
SOURCE: Hi when try to boot my
Hi mohamed04, I recommend you to perform an HDD self test so we can understand if you have a faulty HDD or just a Software problem caused by any windows update or virus that might have corrupted your windows boot file. For performing an HDD self test you should turn on the unit and when HP invent logo appears press " ESC " key, then you will have access to other menu where you should select option " F2 - System Diagnostics" and then " F4 - Hard disk Test" . After process finishes it will provide you a message with " success" or #xx Fail". You need a new hard drive and install fresh windows operating system. Maybe after that you can try to put your old hard drive to external enclosure hard drive and try to recover your computer will recognize the hard drive. Hope this helps, HRH
