Yahoo Mail Logo
Posted on Jul 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Writing Emails When writing Yahoo Emails the letters don't appear on screen at the same time as the keys are pressed. There seems to be a short delay. Also whilst writing an Email the whole thing freezes for a short period. This is a new computer and I've cleaned the hard drive but it makes no difference. I have no problem with typing this message or any other. Is this a Yahoo problem ?
Anonymous
Level 3:
President:
  • Master 828 Answers
  • Posted on Jul 25, 2009
Anonymous
Master
Level 3:
President:
Answers
828
Questions
Helped
382857
Points
3043
Yes it is your Yahoo problem. Install the new Yahoo Messenger on your New Personal Computer. I experience that and made some changes on Settings on my Screen Resolution like from 32Bit to 16Bit Resolution. Good luck!
Anonymous
Level 1:
  • Contributor 31 Answers
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
6782
Points
77
Your computer might be still infected with some virus.
Some viruses dosent clean also after scaning.
its adviced that you back up your all data and once format your PC
please vote
Which key on my laptop computer do I press to change line spacing for writing AOL emails?
The setup is in your AOL software, it is nothing to do with your laptop as AOL uses the browser for this function.
2answers
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Text Mode show on display nokia1600 handset
You can enter text in two different ways: the traditional text
input indicated by , or predictive text input (built-in
dictionary) indicated by .
To use traditional text input, press the key marked with the
letter that you want repeatedly until the letter appears.
To turn on predictive text input when writing text, select
Options > Dictionary and the desired language; to turn it off,
select Options > Dictionary off.
To use predictive text input, do the following:
1. To enter the word you want, press each key once for a
single letter.
2. If the displayed word is the one you want, press 0, and
start writing the next word.
To change the word, press * repeatedly until the word you
want appears.
W r i t e t e x t
24
If ? is displayed after the word, the word is not in the
dictionary. To add the word to the dictionary, select Spell,
enter the word (using traditional text input), and select OK.
Tips for writing text with traditional and predictive text input:
• To add a space, press 0.
• To quickly change the text input method when writing
text, press # repeatedly and check the indicator at the top
of the display.
• To add a number, press and hold the desired number key.
• To get a list of special characters when using traditional
text input, press *; when using predictive text input, press
and hold *.
or check this link
http://nds1.nokia.com/phones/files/guides/Nokia_1600_UG_en.pdf
3helpful
How to undo predictive text v3
Welcome to Fixya. If you want to undo the preddictive text just follow the guide below.
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on Entry SetUp
3. Select the Primary Set Up or Secondary Setup by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
ITAP: it's a built-in software which predicts the word you are typing. THIS IS PREDICTIVE TEXT
TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter F press the number 3 button three times.
Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
To change from one mode to the next you can select it by pressing the top center button from a text entry screen, and Press on Entry Mode. Shortcut: you can press the # key on your phone when you are writing a message and you will see abc1 for your primary mode, 123 for numeric; @ for symbols; and abc2 for your secondary mode.
If you have questions please let me know. Thanks for using Fixya.
2helpful
I have a ROYAL DM80nx organizer and need to know how to change the date and time on it.
press the time button and the press button at the bottom with a key on it. (it has 't.set' in grey writing just above). On the screen - at the top - the first letter should be flashing. To be honest I don't know what it means at the top but you can use the arrow keys to go navigate. The 1st line has the day at the right. The 2nd line has the date - YYYY - MM - DD. On the 3rd line is the time. A=AM, P=PM. HH - MM - SS (Seconds cannot be set but reset to 0 whenever the time is changed).
Dell laptop. writing emails msn not all ltr type
your key board is not working .u have to buy an external key board.
Laptop keyboard email yahoo bang keys to type
are you sure tht you hav the problem only when using yahoo?you had better to go to a srvice center to clean your keyboard.further i request you to provide deatiles or specifications of your lap.
2helpful
2answers
Very slow typing of emails in yahoo. Delay on keystrokes.
ya got a few choices here
1. get a better computer
2. upgrade your computer
3. use a different computer
4. stop using yahoo mail
5. start using other free mail sites
6. stop watchin the clock
7. go to bed and stop stressing that you have a bad computer/internet connection
Sep 30, 2009 • Yahoo Mail
4helpful
How do you change the text message settings to TAP instead of Abc
How to set up Text Entry Mode?
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
  • ITAP: it's a built-in software which predicts the word you are typing.
  • TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter "F" press the number 3 button three times.
  • Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
  • Not finding what you are looking for?
    Top Yahoo Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Sean Wright
    Sean Wright
    ADMIN Andrew
    ADMIN Andrew
    Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
