ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti
lock brake system light comes up when there is issue with car brake systems. It
can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly.
Your vehicles brake system needs inspection.
To
troubleshoot these issues, I suggest you to refer the help links provided below.
There are direct links with accurate solution, for these specific issues.
Click
the link below and follow the procedure: ------
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS
light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control
Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
It
can be issue with master cylinder or the problem is there is still some air
there in the system,that has to be bleed.Or else the parts replaced are not
aligned properly/.I suggest everything back.
There
are few help links mentioned below to troubleshoot the issue.
Click
the link below and follow its procedure:-----
2002 Ford Windstar: Brake Warning
Light ON dash?
http://schematicsdiagram.blogspot.in/2012/06/2002-ford-windstar-brake-warning-light.html
Battery and brake Warning lights on
Dash
http://alltypesofpartsreplacing.blogspot.com/2012/10/battery-and-brake-warning-lights-on-dash.html
ABS & Brake warning lights remains steady
on dash?
Brake warning light comes on and car will not start
intermittently?
http://repairhelpcenter.blogspot.com/2011/12/brake-warning-light-comes-on-and-car.html
When the car stops, abs pump turns ON?
Where is Power Brake Booster located on 1995
Lincoln Town Car?
http://howtobyme.blogspot.com/2011/12/where-is-power-brake-booster-located-on.html
Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
All types of brake problems and
repairs
Brake
Fade Issue?
http://whoisbyme.blogspot.in/2012/07/brake-fade-issue.html
Brake System Troubleshooting?
Car Brake lines have no
pressure?
http://schematicsdiagram.blogspot.com/2011/12/car-brake-lines-have-no-pressure.html
Car Brakes Dragging?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-dragging.html
Car Brakes grabbing?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-grabbing.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Brakes Pulling?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-pulling.html
Pulsating Brake Pedal?
http://repairhelpcenter.blogspot.com/2011/12/pulsating-brake-pedal.html
Spongy brake pedal?
http://repairhelpcenter.blogspot.com/2011/12/spongy-brake-pedal.html
Hard Brake Pedal?
http://repairhelpcenter.blogspot.com/2011/12/hard-brake-pedal.html
Fading Sinking Brake pedal?
http://whoisbyme.blogspot.in/2012/06/fading-sinking-brake-pedal.html
Feels Like Brake pedal Pulsating
http://repairhelpcenter.blogspot.in/2012/06/feels-like-brake-pedal-pulsating.html
What is Brake Drum Bar?
http://repairhelpcenter.blogspot.in/2012/02/what-is-brake-drum-bar.html
ABS light stays on but brakes
work fine?
Vibrations while braking On Chevrolet Van?
http://technoanswers.blogspot.in/2012/04/vibrations-while-braking-on-chevrolet.html
Dragging brakes?
http://howtobyme.blogspot.in/2012/03/dragging-brakes.html
Brake pedal stuck?
http://howtobyme.blogspot.in/2012/03/brake-pedal-stuck.html
After replacing brake rotors and pads, brake pedal
remains on floor?
http://technoanswers.blogspot.in/2012/02/after-replacing-brake-rotors-and-pads.html
How to replace Brake Power Booster?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-brake-power-booster.html
1997 Chevy Tahoe Brake lights not working?
http://technoanswers.blogspot.in/2012/02/1997-chevy-tahoe-brake-lights-not.html
How to service Drum brakes?
http://repairhelpcenter.blogspot.in/2012/02/how-to-service-drum-brakes.html
What type of problems usually noticed on Drum
brakes?
http://repairhelpcenter.blogspot.in/2012/02/what-type-of-problems-usually-noticed.html
How to test Drum Brakes?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-drum-brakes.html
Brake Bleeder Screw Function?
http://repairhelpcenter.blogspot.in/2012/02/brake-bleeder-screw-function.html
Toyota Tundra: Parts diagram to
replace Brake Drums?
http://technoanswers.blogspot.in/2012/06/toyota-tundra-parts-diagram-to-replace.html
Squeak and grinding sound is heard when brakes are
applied?
http://technoanswers.blogspot.in/2012/02/squeak-and-grinding-sound-is-heard-when.html
Brake Pads Inspection on Acura
Integra?
http://repairhelpcenter.blogspot.in/2011/11/brake-pads-inspection-on-acura-integra.html
How to remove Brake Pads on Acura
Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-pads-on-acura.html
How to remove Brake Disc Rotor on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-disc-rotor-on-acura.html
Brake Caliper OVERHAUL on Acura
Integra?
http://repairhelpcenter.blogspot.in/2011/11/brake-caliper-overhaul-on-acura-integra.html
How to remove Brake Caliper on Acura
Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-caliper-on-acura.html
How to remove Parking Brake shoes on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-parking-brake-shoes-on.html
How to remove Parking Brake Cable on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-parking-brake-cable-on.html
Brake pedal is pulsating and vibrating?
http://repairhelpcenter.blogspot.com/2012/01/brake-pedal-is-pulsating-and-vibrating.html
