Mitsubishi XD2000U Multimedia Projector Logo
Posted on Jul 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DLP projector won't show bright images
When ever a bright image comes on during a movie or during my video game session, the screen turns off and goes all blue (no sync) until the bright light is gone. I have to watched everything with no brightness or else this problem happens. My projector is basically unusable at this point
Thanks for any help you guys can give.
Anonymous
Level 2:
  • Expert 82 Answers
  • Posted on Jul 26, 2009
Anonymous
Expert
Level 2:
Answers
82
Questions
0
Helped
37481
Points
179
This unit should be under warranty and can be fixed, also if it is not under warranty, they can also fix it.
check out fixmyprojector.com
2answers
Why does our rear-screen projector (LG BG650/BG630) repeatedly shut down while showing movies?
PDF]User Manual - Projector Central
www.projectorcentral.com/pdf/projector_manual_7815.pdf
Owner's Manual. LCD PROJECTOR. BG630. BG650. Please read the safety ... DivX Video-on-Demand (VOD) movies. ... The product images and On-Screen Display (OSD) in this manual are ..... Turn off power to the lamp and cool down the lamp. ..... 2 After running the WiDi program on your notebook, a list will show all ...
LG BD630: Network Blu-ray Disc™ Player ' LG USA
www.lg.com > Home > Home Video > LG BD630
LG ElectronicsGet information on the LG BD630. ... Component Video Out, 1 (Rear) ... on a big screenunder the stars, our home video players give you the ability to do it all. ... you can not only use your home video player to watch movies from a disc, but ... Projectors: Watch movies outdoors, show a photo montage on your living room wall ...Missing: bg650
Portable LED Projector with Built-in Digital TV Tuner - LG.com
www.lg.com > Home > Home Video > LG PB63U
LG Electronics
1helpful
Need to reduce size of projected image from Senario Torpedo Entertainment Projector. I do not have a user's manual. How can the size of the image be changed?
Many projectors have you twist the lens at the front of the unit (or have a separate adjustment near the front). This unit may not have the option, in which case you will need to adjust the image size by moving the projector closer to the screen.
I have an OPTOMA H27 projector, I am experiencing problems with the quality of the video images displayed. I set the focus by using the internal menu as an image reference. However when I view DVD/Video...
hi,
if u are using the composite video the try component video. composite video will dive u a dull image than component one. also check the distance between the projector an screen.Make sure the projection screen is between the required distance 4.9 to 40.7 feet (1.5 to 12.5 meters) from the projector.
ok
Black dot appears in middle of screen when watching a movie
we changed out the light buld... now it works fine.. funny thing was projector was brand new just out of box... you could see first thing there was a brown spot in the center of the buld creating the spot apparently after it heated up.... thanks again
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
1helpful
Dark or no image at all
CHECK THE LAMP IF THE LAMP LUSTER HAS GONE OUT OR THE FILAMENT AT DOWN PORTION IS BLACK THEN THIS PROBLEM HAPPEN
1helpful
Screen goes blank momentarily
cover up the infrared remote sensor on the projector. The heat of these colours or something might be messinf with the infrared remote sensor. TRy this and see what happens. It may just be bad contacts. Some projectors just cant handle stuff like this. Some were meant for presentations and presentations only. BUt seriously try covering the remote sensor to see what happens. If it is an older projector the infrared signal detector might be sensitive to bright light or stuff like that.
3answers
Why is my projection dark and muddy compared to the brightness on my computer screen?
John here, customer advocate at Dell headquarters. If you can nvigate to the On Screen Display Menu, you should see an "all images" section on the main menu. There you will find brightness, contrast, color temp, white intensity, and gamma controls. You should be able to make adjustments from that menu to sharpen and brighten the image.
Top Mitsubishi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
