After reading RichardAE's solution, I found the resistance across my R2 resistor to be 55,000 ohms. The Grn-Org-Blu-Gld R2 stripes indicate it should be 56,000 ohms,+/-5% (not 5600 ohms per RichardAE's post), so my R2 resistor does not seem to be the problem.
RichardAE indicated he replaced his with a 10,000 ohm resistor. Can anyone verify that this is a suitable solution?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: Onkyo DV-SP301 DVD player stuck in standy mode
Had an Onkyo DV-SP301 that would only intermittently come out of standby. Found faulty resistor R2 on the power supply board (board ORTP-865), it was nominally 5600 ohms, measured much higher. This after checking most p/s caps! R2 runs warm when unit is in standby, so you may want to replace with a higher power rated resistor. I used same rating but 10 k ohm instead, worked fine then.
