I doubt the issue will be the regulators if you have the correct voltage on them.
Check where the hum is coming from.
What frequency is the hum; 50/60HZ = mains hum = bad ground. 100/120HZ = power supply hum.
Affected by a control somewhere maybe.
the motor will have 3 pairs that can be checked with a ohm meter for continuity. each pair has a start and a finish. usually it would be labelled U1 V1 & W1 for the start and U2 V2 & W2 for the end or finish.
To connect in star ( Motors that start with direct load ) supply cables to U1 ( Red ) V1 ( White ) W1 ( blue ) and bridge out U2 V2 & W2.
To connect in delta Supply cables as above. Bridge U2 to V1 - Bridge V2 to W1 - Bridge W2 to U1.
If you have a reversed winding the motor will growl and not turn.
To reverse direction of rotation swap any 2 supply cables ( But only when the power is OFF )
You have a diode arrangement in your power supply that converts the AC power to DC power so that it can be stepped up to operate the high voltage power supply of the set. If those diodes are blown, which happens frequently in a storm, then you have no voltage to your high voltage. You are going to have to check that diode arrangement by making a continuity check both ways on each diode. A diode blocks voltage one way but lets it pass the other way, thus producing a DC voltage.
Hello
It is very give you advice as you are aware of it. So do one thing. As far as the device is not turns on its power, the fault should be somewhere around the power supply system. Begin from AC mains chord itself. Check it for any break. If it is Ok, check whether supply is comming inside to your TV. Normally TVs have DPST type [Double Pole Single Throw] switches used for power switching. If any one of its poles not get correct contact inside, either phase or neutral will be cut. The click sound is not considered for its correct function. Check it also. It can be ckecked by measuring the voltage comes at rectifier points of your TVs power supply regulator section. If there is voltage, check the DC voltage across main filter capacitor. It must be some more than of your supply votage. I don't know the exact voltage you have as mains supply. Here in Idia, we have 220VAC 50Hz. At this supply voltage, DC voltage said above will measure more than 340VDC. Get a comparison with this when you check the voltage at the point mentioned above.
If it is also ok, there may be some fault in the oscillator section of the SMPS [Switched Mode Power Supply] section. There may be transistors or an Ic may be used to make oscillation to drive the switching transistor, which in turn drives the swiching transformer to get proper secondary low DC voltages needed to the circuit board. Check all the transitors. Of optocoupler is used check it also. Check its DC side control drive transistors.
Check all the zener diodes "off circut". ie take it out desoderd and check it with multimeter [preferably analogue type], set to 100K range. There should not be any leak at all. It is best to replace them.
Check all the resistors for its value marked, and all the transistors either for short or open.
Ok.
If your Ideapad is the U3 or U5 version just pop in the disk that you have bought and it will autostart. If your Ideapad is the U1 or U3 (so it doesn't have optical unit) and you have bought the boxed version then your only option is to copy the content of the disk to a USB stick and run the setup from there.
Xerox 6110
Code
Description
A1-1 to A1-32
All indicate a paper path problem, etc. in the ADF
A2
ADF exit problems
A3
Irregular size documents
A5
ADF interlock
A6
ADF single sheet document reset
A7
Platen interlock
A8
ADF exit interlock
C1
Tray 1 jam
C2
Tray 2 jam
C3
Tray 3 jam
C6-1, C6-2
Jams related to duplex
C6-3
Registration sensor, re tray 1
C7-1, C7-2
HCF feed problems
C7-3
Tray 1 feed problem
C8
Paper stays in tray or duplex or HCF
C9
Bypass feed problem
E1-10 to E1-25
Internal jam
E1-6
Paper on registration sensor
E2
Reset signal happened. Might read E-2 something else
E3-30 to E4-14
Exit jam
E3-6
Exit jam
E4-10 to E4-14
Inverter sensor not actuated
E4-15
Inverter sensor
E4-40 to E4-45
Duplex entry sensor
E4-6
Inverter sensor
E5
Front door interlock
E6-1
Tray 1 interlock
E6-2
2 tray or duplex interlock
E6-3
HCF interlock
E7-2, E7-3
Duplex interlock
E8-6 to E8-15
Duplex entry sensor
F1-1
Sorter entry sensor
F1-6
Sorter exit sensor
F3
Paper size not available for sort/stack
F5
Sorter interlock
J1
Add toner
J3
Replace copy cartridge
J7
J8-1
Wrong copy cartridge installed
J8-2
Copy cartridge EEPROM
L6
Auditron or other counter problem
L8
Platen glass temperature is too high
L9
Communication problem between interimage erase/edge lamps and main board
U1-1
Main motor drive problem
U2-1 to U2-4
Scan home sensor
U3-1
Lens sensor
U4-1
Open fuser thermistor
U4-2
Fuser did not warm up properly
U4-3
Fuser temperature too high
U4-4
Fuser problem. Staying on too long
U4-6
High fuser temperature
U5-1
Sorter bin home switch not activated
U5-2
Sorter bin home switch stayed actuated
U5-3, U5-4
U6-1
ROM problem
U6-2
RAM problem
U6-3
Low battery
U6-4
Incorrect value in NVM. Reinitialize main board with code 20-96
U8-1 to U8-6
Problem with exposure lamp, lamp sensor, lamp board
