The Spring is in a Bunker Hill Safe #91006
SOURCE: Battery Change on T-Touch
there usually is an AC contact point to reset digital watches. Touching the + and the ac point with a conductive wire usually resets the watch. Not sure about the spring- I'm not going to open my Tissot up unless I have to.
SOURCE: Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
SOURCE: Casio SPF70 Spring Pins
The best way is to take a look on ebay. The only downside is: you have to buy a whole lot (I mean - you can not buy just a two or three springpins). Go to ebay, choose jewellery and watches and then watch parts and tools or accesories.
The other way is to try to find on internet jewellery and watch part supplyers in your coutry and contact them. They usually selling springpins in packs of 10.
Before you buy any of them, you need to measure the distance between watch case lugs in milimeters. The size between lugs is the exact size for the springpins to order.
If you are not happy with that, then you have to try to continue to visit more jewellers till you find the right ones.
Don't forget to rate, please.
SOURCE: Can't remember where the little spring go in the g-shock 300
The used of the spring of your watch is for the speaker connection of the back cover of your watch. Your watch is still working even without the spring but no sound of alarm or whatever sound feature.Just go to watch service center im sure they have spear for the spring if not they can make spring from the watch spring bars.
Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
SOURCE: My Casio Pathfinder SPF40 (2273 module) has 3
Yes Where the scew holes are for the back plate you will see two smaller holes located outside the seal groove. The spring goes in the left one.
