2007 Suzuki XL-7 Logo
Rene Posted on Mar 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
07 suzuki xl7 po420 code. Oxygen sensor bank 2 sensor 1 i believe. Location in the engine. Thanks..
_-__-___-_
Level 3:
  • Suzuki Master 20,706 Answers
  • Posted on Mar 12, 2017
_-__-___-_
Suzuki Master
Level 3:
Answers
20706
Questions
Helped
6804906
Points
57965
The cold from hell,,
CAT monitor. know it well, too well.
no its not that.
the code tells that engine has a lazy or dead cat.
no engine stated.
its and XL-7 not and XL7, they are different cars.
3.6L V6
bank one is failing the person who told you bank 2 is full of beans.
"Catalyst Efficiency Below Normal (Bank 1)" SM quote. we change the front B1S1 front sensor first.
then the B1S2, sensor next.
then the CAT if sure no exhaust leaks are on Bank1.
S1 is front
S2 is rear
bank 1, is cylinder 1 side
bank 1 is,, right bank, usa is passenger side
look for leaks first in exhuast
then bad 02s, on right side , damage to wires.
the new sensors.
then new cat, $$$$$$$$$$$$$$$$$$$ last
5 Related Answers
txkjun
John Weathers
  • 409 Answers
  • Posted on Dec 26, 2008
SOURCE: check engine light come on fault codes PO165 and PO155
Yes sorry but they both should be replaced.
Anonymous
  • 61 Answers
  • Posted on Apr 22, 2009
SOURCE: location of oxygen sensor
There is only 4 sensors on a 2000 dodge intrepid and the bank 2 sensor 2 is the sensor located on the right (passenger) side and the one located after the catalytic converter (the one close to the firewall).
Anonymous
  • 2049 Answers
  • Posted on Oct 20, 2009
SOURCE: location of the bank 1 sensor 2 O2 sensor on a 2001 ford escape
B1 means the sensor is located on the same bank of the engine that has the #1 cylinder. B2 is located on the opposite bank.
S1 means the sensor is located BEFORE the catalytic converter
S2 means the sensor is located AFTER the catalytic converter
You didn't say which engine you have, so I've included the diagrams of both 4 cyl and 6 cyl so you can see the banks
gtyner
  • 280 Answers
  • Posted on Mar 11, 2010
SOURCE: suzuki xl7 which side is bank 2 sensor 2
I assume then that this is a v6. Bank one should be the drivers side (I think) . Sensor 1 would be the one before the catalytc convertor and sensor 2 would be the one after it.
2strokeJim
2strokeJim
  • 577 Answers
  • Posted on Feb 07, 2012
SOURCE: location of oxygen sensor bank 2 sensor 2 for gmc sierra 1500 v8
Bank 2 is the bank that is farther back than the other when looking at eng from the front you will see that one cyl head is farther forward (closer to radiator than the other. this is #1 Bank) #2 is the opposite and sensor #2 is the one after the Catyliac Convertor towards the muffler. #1 sensor is between head and Cat.
Suzuki XL7 3.7, 4x4. Where is bank 2 sensor 2. 3.7 4x4 Suzuki XL7
Question edited for clarity and correct order 'make model 'stuff'.
Question moved to model category.
Passenger side and after the catalytic converter.
https://www.justanswer.com/car/7vwre-getting-code-p0031-2002-suzuki-xl-7-2-7l.html
Oxygen Sensor locations - 2003 Suzuki XL-7
RepairPal.com https://repairpal.com > ... > Suzuki > XL-7 > 2003
Feb 12, 2010 - Driver's side of the engine is bank 1, so passenger side is bank 2, sensor one is engine side of cat converter. Sign in to reply.
where is the low and high side o2 sensor located
Jun 19, 2010
Where is located the knock sensor bank 2 on a 07 Suzuki XL-7
Jun 20, 2018
More results from repairpal.com
2005 Dodge Durango 4.7 giving a P0175 code. Could it be a leaky exhaust manifold?
Did you clean the Throttle body? That is often the cause of a rough idle.
The Fuel Air o2 sensor on the manifold is often hard to reach, but the downstream o2 sensor after the catalytic converter is easier to get to.
Code P0172 indicates Bank 1 of the engine has a rich fuel mixture. P0175 indicates Bank 2 of the engine has a rich fuel mixture. Engine Bank 1 is the same side of the engine as Engine Cylinder 1. Engine Bank 2 is the opposite side of the engine. A firing order and cylinder location diagram may be needed to see which side of the engine is Bank 1 or Bank 2.
P0172 is triggered by the engine bank 1?"upstream" oxygen sensor and P0175 is triggered by the engine bank 2 "upstream" oxygen sensor. The oxygen sensor alerts your system when the condition is too rich meaning there's too much fuel int the exhaust stream or too little oxygen in the exhaust stream. The symptoms and causes will help you determine the exact issue and how to fix it.
Your bank 1 or bank 2 sensors will be referred to as "sensor 1" or "sensor 2". Sensor 1 refers to "upstream" sensors, or the ones near the engine and before the catalytic converter. Sensor 2 is "downstream" or after the converter.
Location
https://www.google.com/search?q=2005+Dodge+Durango+4.7+engine+bank+2+upstream%E2%80%9D+oxygen+sensor+location
all about the code
https://www.google.com/search?q=2005+Dodge+Durango+4.7+P0175+code&
Battery condition?
https://www.dodgedurango.net/threads/05-4-7l-codes-p0172-and-p0175.77565/
P0017 on a 2007 suzuki xl7
very old post.
that code is in the FSM buy an FSM
or log in to alldata.com and see true meaning,
i believe this is unique to suzuki and only your car./engine and body.
3.6L v6 , the pregnant version of my 2.5L
change the water pump on this engine sux.. big time.
Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor "B"
Number of Trips to Set Code: 2
Trouble Code Conditions:
Difference between camshaft (bank 1 / exhaust side) position and crankshaft position is out of specified range.
Possible Causes:
  • CMP sensor
  • CKP sensor
  • Signal rotor
  • Timing chain
  • Timing chain tensioner
  • CMP actuator
  • ECM
loose chain? or the can be a dead (jammed) tensioner.
if crazy loose it can skip a sproket tooth, do you ignore chain noise?
1helpful
did you look it up?
alldata.com shows.
it means the engine needs service and inspections here.
Possible Causes:
  • CMP sensor
  • CKP sensor
  • Signal rotor
  • Timing chain
  • CMP actuator
  • ECM
1helpful
Code of PO174 1 system too lean (bank 1) Code PO420 Catalyst efficiency below threshold (bank 1) Code PO430 Catalyst efficiency below threshold (bank 2)
hi,my friend, you can try,
Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required.
Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady).
Inspect the downstream heated oxygen sensor (HO2), replace if necessary
Replace the catalytic converter
My 2000 Cadillac Deville engine light on. Engine code PO420
Catalyst System Efficiency Below Threshold (Bank 1)
A code PO420 may mean that one or more of the following has happened:
  • Leaded fuel was used where unleaded was called for
  • An oxygen sensor is not reading (functioning) properly
  • The engine coolant temperature sensor is not working properly
  • Damaged or leaking exhaust manifold / catalytic converter / exhaust pipe
  • Retarded spark timing
  • The oxygen sensors in front and behind the converter are reporting too similar of reading
  • Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required.
  • Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady).
  • Inspect the downstream heated oxygen sensor (HO2), replace if necessary
  • Replace the catalytic converter
1995 Cadi SLS Codes, P0030 & P0036, Ckt Fuse or Relay Defective, checked fuse ok, where is relay located?
P0030 = HO2S Heater Control Circuit (Bank 1 Sensor 1) - No.1 Heated Oxygen sensor on bank 1.
P0036 = HO2S Heater Control Circuit (Bank 1 Sensor 2) - No. 2 Heated Oxygen sensor on bank 1
For both of these to trigger on the same bank, means most likely an Open or Short to Ground condition (somewhere on the Bank 1 circuit) stopping the HO2 sensors from reaching their working temperature.
Check the following in this order:
1) Using a multimeter, check 'continuity' of the Oxygen circuit FUSE terminals (don't rely on visual inspection alone) or replace fuse with a known good one.
2) Check for moisture getting into both oxygen sensor connector terminals (bank 1).
3) Check for good connection at Oxygen sensors (bank 1).
3) Have both heated oxygen sensors on Bank 1 tested (ensure their values are to specification).
4) Check HO2 pin-outs of the PCM for correct voltage.
Only replace the HO2 sensors as a last resort (if out of spec).
Then engine department relay centre & fusebox location is behind the washer bottle, but I believe the HO2 sensors are connected direct to the PCM, not a relay.
Cheers,
"If this has helped you in any way, please rate this solution"
1helpful
Suzuki xl7 which side is bank 2 sensor 2
15helpful
3answers
How many oxygen sensors in a 2001 chrysler sebring 3.0
Fig. Heated Oxygen (HO2S) location (sensor 1)-2.4L engine
Fig. Heated Oxygen (HO2S) location (sensor 2)-2.4L engine
Fig. Heated Oxygen (HO2S) location (bank 1, sensor 2) (bank 2, sensor 2)-2.7L engine
Fig. Heated Oxygen (HO2S) location (bank 2, sensor 1)-2.7L engine
I hope help you with this (rated this help). Good luck.
1helpful
Ihave a 2002 suzuki xl7 and i have a error code low voltage bank 2 sensor 1. is this the oxygen sensor on the passenger side before the cat?
Yes, If you have dual exhaust pipes coming from the engine, Look on the passenger side exhause pipe, and it will be the 1st sensor on the pipe coming out of the engine.
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Suzuki Expert? Answer questions, earn points and help others
