Ovens Logo
zenzele mackenzie Posted on Mar 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Imperial oven will light but will go off when you turn on more than two Cooker burners. What could be the cause ?
Dennis Boxerman
Level 3:
  • Master 1,306 Answers
  • Posted on Dec 17, 2017
Dennis Boxerman
Master
Level 3:
Answers
1306
Questions
Helped
647079
Points
2787
This is usually and indication of a gas issue. either a gas pressure issue or the cut off valve not open all the way, or the hose connection is not completely on if it is a snap-on type.
4 Related Answers
Anonymous
  • Posted on May 28, 2010
SOURCE: our imperial convection oven will not light. NO ignition
Your door switch is not reading that the unit is closed
Anonymous
  • 11896 Answers
  • Posted on Oct 18, 2010
SOURCE: Smeg A2 cooker, 11 2years
Is this gas or electric? If it is electric, you will want to test the power to the burners with a voltmeter. This will tell you if the control is bad and not giving power to the burner, or if the burners themselves are bad or possibly just loose or corroded connections.
If you have gas, check the gas valve and the tubing. Make sure there are no holes or gaps letting out the gas, make sure the valves is completely up to allow full gas flow. Also check that the tubing is clean of debris.
Anonymous
  • 25 Answers
  • Posted on Oct 23, 2010
SOURCE: whirlpool imperial series 465 electric
There is a fault on your plate sensor (the rod crossing through the center of the plate). You should be able to get a replacement if not you can replace the plate, but my advice is just ignore it. Its only there to make you aware that the surface is still hot during and after use.
Anonymous
  • 2341 Answers
  • Posted on Oct 08, 2011
SOURCE: whirlpool imperial series electric oven does not
Since basically nothing works,nither oven nor the surface burners, the first thing ya should be checking is for a burnt or broken wire connection on the back where the cord connects to the house wiring also need to check for a bad circuit breaker its possible for the breaker to appear to be on yet be burnt out internally....of course i would reccomend that if the wires on the back aren't burnt that ya call a electriction and not go inside of your breaker panel since it could be very dangerous unless your confident with electric work.
GENE
1helpful
Imperial single older convection ICV pilot lights, have flame, but wont light / heat oven. replaced thermostat, didnt help problem, now what?
I suspect the thermo coupler if there is one. I had to replace ours. I took it out and took it to a repair man and he sold me one just like it. Works good now. Make sure the parts are clean where the gas comes out as well The burner as well.
Why won't burners stay on
Alguien puede ayudarme con el diagrama electrico del horno imperial
gracias
What causes the flame switch to cut out ion an Imperial ICVD convection oven
This flame sensor switch is a safety device that only allows the main valve to open after is is satisfied there is a pilot flame. Otherwise if there were no pilot and the main valve was allowed to open, the inside of the burner area would quickly fill with gas and pose an exposion hazard. The original capillary tube type switch is obsolete and a new electronic unit conversion kit is available. Contact Imperial tech support for more information
Need to know what commission my imperial cooker 6 burnerand griddle range
I could help with this but I need more information to answer your question. What do you mean with the word commission?
Imperial Infra-Red Salamander Broiler back fire blow the fire off
If it has ceramic burners and it banged and went out the chances are the seals are loose around the ceramic plaques. Unfortunately that means a new burner.
2answers
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 • Ovens
IMPERIAL ICV-1 SINGLE DECK CONVENCTION OVEN
this is a common indication that the ignition module is probably going bad or the flame sensor is not sensing the flame on the burners. There are other, more technical issues possible but this is usually the most common. The "not restart" , if referring to the burners, is an indication that the ignition module has "locked out" the system, usually after 3 failures of attempts to light the burners.
Imperial oven
No not really. If you can see the burners, do they go off completely because they should. If not, maybe a faulty gas valve.
Top Imperial Ovens Experts
john h
Kardoc
David Spradling
David Spradling
Are you an Imperial Oven Expert? Answer questions, earn points and help others
