Question about Imperial ICVD-1-H Turbo-Flow Gas Single Oven
IMPERIAL ICV-1 SINGLE DECK CONVENCTION OVEN
WHEN I SWITCH THE OVEN ON I CAN HEAR THE SOUND OF THE PIOT AND THE BURNERS IGNITE. THEN THE OVEN STOPS FOR A FEW SECONDS. THIS HAPPEN SEVERAL TIMES BEFORE THE BURNERS FINALLY STAY ON . IT WILL TAKE OVER 10/ 15 MINUTES
SOMETIMES WHEN THE OVEN IS ON AND REACHES THE MAX TEMP THE BURNERS SUDDENLY SWITH OFF AND THEY DO NOT RESTART.
Posted by ciccione on
Dennis Boxerman
  • 1,306 Answers
This is a common indication that the ignition module is probably going bad or the flame sensor is not sensing the flame on the burners. There are other, more technical issues possible but this is usually the most common. The "not restart" , if referring to the burners, is an indication that the ignition module has "locked out" the system, usually after 3 failures of attempts to light the burners.
Posted on Dec 17, 2017
2 Related Answers
Anonymous
  • 68 Answers
SOURCE: ICV-1
If you could narrow down the buzzing noise, where and when, it may be significant.
As far as the unit losing its flame, I believe this unit uses a "flame switch" to prove there is a pilot flame. (Part# 1133) So first visually verify the flame quality and the position of the bulb for the flame switch. And assuming that's fine, you need to check the electrical switch portion of the part. It is in the control cabinet towards the bottom. Just two wires.
Usually this problem is a switch failure, rather than a lose connection, or a poor pilot flame. Good luck
Posted on May 30, 2008
Anonymous
SOURCE: No ignition
EL HORNO NO SE APAGA EN LA TEMPERATURA SELECCIONADA Y CALIENTA DEMASIADO
Posted on Feb 04, 2011
Imperial icve-1 standard depth 208/240 volt connextion help
Are you in the EU or US and can you be more specific, it is fairly straight forward. If in doubt get a professional to connect it for you.
Imperial icv-1 electric oven
Not sure what type of oven you are having, Gas or Electric ?
Why won't burners stay on
Alguien puede ayudarme con el diagrama electrico del horno imperial
gracias
Our kitchen uses the Imperial IVC-1 after it reaches temp it cuts off and inttermitently will not fire again unless it is turned off then back on. what in going on
Not sure if you have electronic or mechanical thermostat. However problem is likely to be in the electronic ignition sequence box (Usually a Fenwall) Also check the panel cooling fan is working, it cools the Fenwall box.
I put in a new switch for the top oven but the convection fan is going on only in cool down mode not on oven mode. it should go on when oven turns on (button up) but goes on when button clicks down (cool...
Door needs to be closed in cook mode to work. You sure you put the switch in the right way up? Also you could have a dodgy door switch as the cook/cool switch and the door switch operate as a two-way circuit.
No ignition
What is the size of the gas intake on the back of the ICV-1
http://www.imperialrange.com/manuals/icvManual.pdf
Go to their web site and check out this manual. On page 3 of "Gas Connections", it says that a 3/4" pipe connection is used.
Hope this helps ya.
ICV-1
Imperial ICVD-1-H Turbo-Flow Gas Single Oven Logo
Top Imperial Ovens Experts
Dan Webster
Dan Webster
Dennis Boxerman
john h
Are you an Imperial Oven Expert? Answer questions, earn points and help others
