SOURCE: COD MAN TGA EDC
EDC Electronic deisel control
03050 After run test, zero quantity
03 implausible
SOURCE: I have problem with my MAN truck TGA 33.400 It
EDC 03779-10 = Fuel pressure too low in the common rail.
Start by checking the fuel filters and the likes for deposits or leaks. Then take it to a repair shop and have them check the fuel pump itself. Finally they will have to dismantle the common rail and the injectors to check for abnormal wear.
This is a big job and if the pump will have to be replaced, very expensive.
SOURCE: I have problem with my MAN truck TGA 18.350 It seems to me in the dashboard EDC 03778-10 diagnosis.
man tga code 03778 /03779
SOURCE: my track man tga show EDC 00637-03 what mean and show me please
is that a DUMP truck?
this?
http://www.heavytrucks.co.nz/new-trucks/man-trucks/tga-range/
SOURCE: my man tga tuck show this on dashboard edc 03779-10 what is the meaning
The following link provides the brief explanation of the error codes. The EDC code reported is likely related to the common rail fuel delivery system. It will likely take specialized equipment to diagnose the problem properly only available at a service center.
Hope this helps?
http://www.techtransa.lt/MAN_klaidu_kodai.pdf
1.EDC:00959-01
>seconds-Action-Tachometer has lost memory and is not aligning with the Edc
Control unit. mixture of time and date>Tachometer to be reprogrammed.
2. EDC:00960-01>minutes-
Action-Tachometer has lost memory and is not aligning with the Edc Control
3. EDC:00961-01>hour-
4. EDC:00962-01>Day-
5. EDC:00963-01>Month-
6. EDC:00964-01>Year-
