okay, it is for the gameboy, but played on the DS. Spongebob, the movie. Assume that you have to get bonus points to jump out of the first "hole" to continue the game?okay, it is for the gameboy, but played on the DS. Spongebob, the movie. Assume that you have to get bonus points to jump out of the first "hole" to continue the game?
are you sure the game is for DS because i cant find it anywhere, only for ps2, gameboy & gamecube
i have a guide for SpongeBob SquarePants: The Yellow Avenger if thats the one your on about.are you sure the game is for DS because i cant find it anywhere, only for ps2, gameboy & gamecube
You can't post conmments that contain an email address.
you need to do a wall jump. jump up to the wall, wate for smoke to appear on marios arm and then prees a. oh and on the title screen at the start, hold L&R at the same time and select ur file to play as luigi. just in case u didnt alredy know.
if it is the first star (with tube and pirana plant sticking out of the wall) wall jump (slide on the wall (hold direction that the wall is in with the control pad)and press A while sliding)
try holding the button toward the wall so that you slide down it a little bit. then when you jumphold in the opposite direction. If you triple-jump (three jumps in succession) you can get higher than normal so you can prepare
The second coin is around the very middle of this stage. It can be rather easy to miss if you take the first pipe near the middle of the stage up into the clouds.
If you skip this pipe and enter the next one and it'll launch you over a rock wall and over another pipe that'll send you back. If you continue forward you'll notice there is a ceiling of rock above you with an open area. Wait for the water to rise and swim up to the top. The second star coin should be there.
If you take the first pipe into the clouds then you'll exit out of an orange pipe. You can back track to the left and get the coin that way too. Though you'll need to wall jump to get over the rock walls in your way.
Incase you have trouble with wall jumping I'll give you some tips. To wall jump you just jump against the wall and hold the direction the wall is in. Mario should lean and slide against it. Press jump and you'll fly off in the other direction. If you are between two walls you can use this technique to jump back and fourth up the walls in old video game wall jumping style. Just alternate directions accordingly and press jump when you are on the wall. The timing shouldn't be too hard, but remember to practice it till you get it. don't worry about the time either, you can always try again if you want to.
if you are stuck where I think you are what you need to do is jump over the square box and then push it back onto the pressure plate. This will activate the valve higher up. You can still pull the large lever down to make the spanners work and walk over the steam pipes. Hopes this helps.
