SOURCE: remote code
Here is your manual
http://www.ofausa.com/remote_manual/URC4110%20manual%20booklet.QXD.pdf
Here are your codes
http://www.ofausa.com/list_codes.php?db_value=access4&remote_choice=URC4110
SOURCE: need to program one for all urc3220 remote control
To search for a code for your TV:
On the remote control, press TV once.
Press and hold SET until the LED (red light) blinks twice,
then release SET.
Enter 9 - 9 - 1.The LED will blink twice.
Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH+, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
To lock in the code, press and release SET.The LED will
blink twice.
To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
Hope this helps. :}
SOURCE: I need codes for a symphonic tv I have a urc3220
Here are the codes
Symphonic
0180 0171
And here is how to set it up.
http://www.oneforall-na.com/set_up_remote.php
Good Luck Please Rate FixYa!
SOURCE: urc3220 remote
I can help you with your URC-3220 Universal Remote Control issues.
The
URC-3220 codes for Apex TV's are: 0748, 0765, & 0767.
For
complete
instructions on entering the URC-3220 remote codes, please refer to my
posted Fixya Tip One For All URC-3220 Code
Entry.
I hope that helps.
_______________________________________________
One For All URC-3220 Manual
One For All URC-3220 Code List
Entry
Search
One For All URC-3220 Reassign
Key
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
