Rca tv model 20F512
Do you mean the URC 3220 from One For All? The RCA codes programmed into the unit are 0047 0019 0018 0090 0679
0747 1047 1147 1247 1347 1447 . The manual for the URC3220 is available here: http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/URC3220%20manual%20booklet.1.2.pdf . The directions for programming the remote are here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/7725/~/programming-the-one-for-all-urc3220-universal-remote-control .
Note: if the TV is a 20F512T, it was built by TTE for RCA in ~2006. The URC3220 was programmed in early 2006. This may mean that your remote doesn't have the code for your TV. Universal remotes usually only have codes for devices released 6 months or more before the remote was programmed. You may need a newer remote.
I hope this helps.
SOURCE: urc 3220
I was looking for hours online, I looked on these kinds of sites at least twenty times and tried all the suggested codes and websites and it didn't work, but I finally used 0171 for my URC-3220 universal remote control and it worked :).
SOURCE: I need the RCA remote code for Durabrand tv
Since the Funai code does not work, you have to use the CODE SEARCH feature.
The remote may already be set up to operate your brand of TV, VCR, Laserdisc, Satellite Receiver, Audio Equipment, or Cable Box. It is pre-programmed with the following codes: TV-000, VCR1-000, AUDIO-003, and SAT•Cable Box-000. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond,
repeat steps 1-7.
Programming Your Universal Remote
SOURCE: I need ONE FOR ALL remote control urc 3220 code for TV
I need a code for GE 24912 universal remote for Element tv FLW1920B
SOURCE: I NEED HELP FIND CODES FOR ONE FOR ALL URC-3220
Je désire le code pour une telé. ancienne PANASONIC
PC 29 SF 84A
