H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
For free DIY and other help and advice, feel free to contact me via my site.
Always include your FULL model number*, FCC ID number*, and detailed symptom information.
* from the tag in the cooking cavity or elsewhere on the oven (or send a clear photo of tag)
William E. Miller
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
H97, H98 and H99
appears in display window a short time alter start key is pressed and
no microwave oscillation.
NOTE:
DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
H97, H98 and H99 appears in
display window a short time alter start key is pressed and no microwave
oscillation.
NOTE:
- Check magnetron filament for open or short to casing before proceeding to determine a good magnetron.
