LN52A550P3FXZA TV. The T-con board is responsible for the image processing and video output, and a malfunctioning T-con board can cause a loud noise and a scrambled screen.
Other possible causes could be a faulty mainboard or power supply, damaged or loose cable connections, or a malfunctioning panel.
I recommend attempting the following steps before seeking professional help:
- Check all cable connections to make sure they are securely plugged in and not damaged.
- Unplug the TV for at least 30 seconds and then plug it back in.
- Try a different input source to see if the problem is with the source or the TV.
- Perform a factory reset on the TV by going to the menu and selecting Support > Self Diagnosis > Reset.
- If none of the above steps work, it may be necessary to contact a professional repair service or Samsung customer service for further assistance.
Contact union electronics 1 800 648 6657 Julio [email protected]
