Low beam ? high beam ? DRL - daytime running lamps ?
F1 CHECK THE HIGH BEAM CIRCUIT FOR SHORT TO POWER
Pull CJB Fuse 16 (20A) - central junction box ,inside the vehicle ! Ignition on !
http://www.bbbind.com/free_tsb.html Do you know how to use a wiring diagram ? Videos on youtube .
No - REINSTALL the fuse.GO to F12 .
No - REINSTALL the fuses. If equipped with daytime running lamps (DRL), GO to F3 .
If not equipped with DRL, GO to F6 .
F3 CHECK CIRCUIT 13 (RD/BK) FOR SHORT TO POWER
do you know how to do this test ?
pull the
DRL Relay 2
Yes REPAIR circuit 13 (RD/BK). TEST the system for normal operation.
No GO to F4 .
No GO to F4 .
F4 CHECK THE DRL RELAY 2
Carry out the relay test for the DRL relay 2; refer to Wiring Diagrams, Cell 149, Component Testing.
Yes GO to F5 .
No INSTALL a new DRL relay 2. TEST the system for normal operation.
F5 CHECK CIRCUIT 1032 (WH/BK) FOR SHORT TO POWER
Measure the voltage between DRL relay 2 pin 2, circuit 1032 (WH/BK), harness side, and ground.
Yes REPAIR the circuit. TEST the system for normal operation.
No GO to F6 .
F6 CHECK CIRCUIT 1033 (RD/YE) FOR SHORT TO POWER
Multifunction Switch C259
Measure the voltage between multifunction switch C259 pin 507, circuit 1033 (RD/YE), harness side, and ground.
Yes If equipped with DRL, REPAIR circuit 1033 (RD/YE). If without DRL, REPAIR circuit 13 (RD/BK), circuit 1033 (RD/YE), or DRL jumper as necessary. TEST the system for normal operation.
No If equipped with autolamps, GO to F7 . If without auto lamps, GO to F11 .
F7 CHECK THE HEADLAMP RELAY
Carry out the relay test for the headlamp relay; refer to Wiring Diagrams, Cell 149, Component Testing.
Yes GO to F8 .
No INSTALL a new headlamp relay. TEST the system for normal operation.
F8 CHECK CIRCUIT 7 (LG/YE) FOR SHORT TO POWER
Light Sensor Amplifier C216
Rap Module C257
Park Lamp Relay
Measure the voltage between headlamp relay pin 2, circuit 7 (LG/YE), harness side, and ground.
No GO to F9 .
F9 CHECK THE HEADLAMPS FOR ILLUMINATION
Check the headlamps for illumination.
Yes GO to F10 .
No CHECK the headlamps while reconnecting the RAP module and light sensor amplifier. INSTALL a new RAP module or light sensor amplifier as necessary. TEST the system for normal operation.
F10 CHECK CIRCUIT 15 (RD/YE) FOR SHORT TO POWER
Measure the voltage between multifunction switch C259 pin 15, circuit 15 (RD/YE), harness side, and ground.
No GO to F11 .
F11 CHECK THE MULTIFUNCTION SWITCH
Carry out the multifunction switch component test; refer to Wiring Diagrams, Cell 149, Component Testing.
Yes INSTALL a new headlamp switch; REFER to Lamp Switch-Headlamp . TEST the system for normal operation.
No INSTALL a new multifunction switch; REFER to Section 211-05 . TEST the system for normal operation.
F12 CHECK CIRCUIT 632 (GY/OG) FOR SHORT TO POWER
Measure the voltage between multifunction switch C259 pin 12, circuit 632 (GY/OG), harness side, and ground.
Also
i suggest you to refer these gear shift issues, which are mostly noticed. These
are direct links with appropriate solutions to
the specific problems of gear ****.
GEAR SHIFT ISSUES
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
The
shifter needs to be inspected. The shifter assembly is got misaligned, it has
to be open and realign.
There
are many other possibilities. But if it was working right up till now and
suddenly this occurred then its shifter
assembly alignment issue.
Also
GEAR SHIFT ISSUES
Thanks.
The
There
Also
GEAR SHIFT ISSUES
Thanks.
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
1996 Toyota Corolla: Transmission
Shift Interlock will not Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
Gear
indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of
Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
Automatic transmission will not go into high
gear?
Car won't downshift sometimes?
Buick Park Avenue: Transmission will
Not shift into drive?
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
Third gear missing and engine losing power?
Chevrolet silverado has whining sound in gear?
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
Car hard shift at slow speeds?
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
2000 Nissan maxima shifts hard?
Vehicle noticed sluggish delayed shifts while
driving?
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
Thanks.
http://howtobyme.blogspot.com/2011/11/highbeams-stopped-working-but.html
Only one head light
works on 2001 Dodge Caravan?
http://howtobyme.blogspot.com/2011/11/only-one-head-light-works-on-2001-dodge.html
Headlight Assembly Removal On Honda Accord
http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html
Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html-----------
All headlights not working?
http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
Headlight wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
Dash Lights And Front
Marker Lights Flashing On And Off
http://schematicsdiagram.blogspot.com/2012/10/dash-lights-and-front-marker-lights.html
2001 Chevrolet Tracker: Headlights and Dash
lights Pulsating?
http://whoisbyme.blogspot.in/2012/06/2001-chevrolet-tracker-headlights-and.html
No parking lights and headlights not turning OFF?
http://technoanswers.blogspot.com/2012/01/no-parking-lights-and-headlights-not.html
How to replace HID headlight bulbs for lexus
400h?
http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
Head
Lights Comes ON by Itself?
http://whoisbyme.blogspot.in/2012/07/head-lights-comes-on-by-itself.html
Only high beams work but head lights not
working on Ford F350?
http://howtobyme.blogspot.com/2011/11/only-high-beams-work-but-head-lights.html
http://howtobyme.blogspot.com/2011/12/how-to-replace-headlight-bulbs-on.html http://repairhelpcenter.blogspot.com/2011/12/how-to-change-headlight.html ------------- http://technoanswers.blogspot.com/2012/01/headlights-will-not-turn-off-on-ford.html ---------- http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html --------- http://technoanswers.blogspot.in/2012/02/hummers-headlights-flashes-while-start.html ---------- http://schematicsdiagram.blogspot.in/2012/02/using-non-afs-headlamp-assembly-for-afs.html ------------ How to
replace Headlight Bulb on 2001 mitsubishi magna
Only high beams working on GMC Savana?---------
• Working of Headlight switch?
• Both headlight bulbs blow together?
• Car headlight bulbs don't last long?
How to replace Headlight Bulbs on Lincoln
Town Car?
How to change headlight?
Both headlights and turn signals not working?
http://schematicsdiagram.blogspot.com/2011/12/both-headlights-and-turnsignals-not.html
Headlights will not turn OFF on Ford expedition and car trailer?
Headlight Assembly Removal on 2010 buick lacrosse?
http://technoanswers.blogspot.in/2012/04/headlight-assembly-removal-on-2010.html
Headlights flickering and car hesitates to
start?
Hummers headlights flashes while start?
Using non-AFS headlamp assembly for AFS
assembly?
http://www.howtorepairguide.com/2012/10/how-to-replace-headlight-bulb-on-2001.html
Thanks.
gear?
Buick Park Avenue: Transmission will Not
shift into drive?
No
is turned ON?
Issue?
mornings?
driving?
Park Mode?
These will help.
Thanks.
