These logs have not been cut to size. They we're simply felled in this size. They also have not been transformed in any way. Two or three may be laid together. Decision 23/1 is relevant but not directly on point. Decision 24/7 is also relevant.
SOURCE: Using logs
Here something that would help you:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
so log 24 base 2 it's log 24 / log 2 etc.
and if i get right what you wrote x= 10 ^ ( 3 * (log 5) ) if no inverse it it's easy really Hope it's helped you.
SOURCE: what is the maximum length of exhaust venting that one can use
According to the manual the longest run of pipe that can be used is 78.7" (6'6.7"), but the maximum termination height is 51.2" (4'3.2"). Hope this helps
http://www.delonghi.com/delonghi/data/int/usa/libretti.nsf/d43b2a60086dfe93c1256a47004ad1f5/37974a66fe82678885256f1200671bfa/$FILE/CF210.pdf
Testimonial: "Thanks so much, most helpful"
SOURCE: DSL connection not being shared by Linksys RV042 Dual Wan router
Looks like your "modem" is actually a gateway, as is common with DSL devices. It's acting like a modem and a router. So you're actually connecting a router to your RV42. You could get this to work a couple ways.
1. Leave the modem acting like a router and configure the WAN connection on the RV42 as a static IP, and use the IP of the modem. You may also be able to use "obtain IP automatically" in the WAN connection. This way, the modem stores your PPOE information and just forwards the traffic to the RV42. Any devices behind the RV42 won't know the difference.
2. Configure the modem as just a modem (no routing). Your ISP should be able to talk you through this, but in the modem configuration you can look for what's usually called "bridged mode." Then you would enter the PPOE information in the RV42. This is my preferred method.
SOURCE: I purchase a lowrance LMS-520C about 18 months
If your problem happens mostly in weedy area's, you should try downloading the latest version of software from the lowrance site. It's Ver 2.5.0. You also need to change your fishing mode to "shallow water". I experienced the problem as described on the site, and the download fixed it.
Hope this helps you.
SOURCE: my dyson dc18 loosing suction , took apart and
Hi its Darran at Dyson.
A loss of performance is normally attributed to a blockage or a dirty filter. Please ensure you follow the full blockage procedure outlined in your user guide or in the Support sectino on our website at www.dyson.com.
You will also find information here on checking the cleaner head to ensure the brush bar is turning and instructions on how to wash the pre filter.
I hope that this information is useful to you and should you need any further help or advice, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
