Blenders Logo
Max Raymond Posted on Jan 02, 2017
How do you take it apart ? model 6889 blender bottom won't come off
Ninja Blender BL700 30. I need to find a replacement lid please
Question edited for clarity and English.
Question moved from Washing Machines category.
All parts are available on Amazon and from the maker, Ninja Kitchen.
https://www.google.com/search?q=Ninja+Blender+BL700+30.+replacement+lid
I have a Brown ooze coming out of the engine compartment of my blender
Perhaps your engine needs and oil change Donald :>D
It is generally food that has leaked through the bottom seals, or it is grease. Take it apart, clean and lubricate. The screws are normally hidden under the feet.
Or, treat yourself to a new one and give the old one to Goodwill.
I took my blender apart and can’t figure out how to get it back together. Where do the parts go on the the front part so it won’t leak?
Manufacture and model number?
Upload a picture or two to ask?
Contact a local repair service instead?
Jul 02, 2018 • Blenders
Krups blender switch lights, but motor doesn't turn
Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
kolbrun
Kitchenaid blender model # KSB565OB0 is leaking from the bottom. I have taken it apart to try and find the problem. The gasket is fine and the pitcher attaches and locks but it still leaks everytime we...
Check for cracks in the bottom of the glass.If it continues leaking then the gasket is compressed and no matter if it visually looks good, cause it has lost their sealant skills. Replace the gasket
BIBC1030 Blender: I won the Wolfgang Puck Immersion Blender/Chopper ...
Replacement parts for Wolfgang Puck Immersion Blenders are available here:
http://www.wpcookware.com/categories.asp?cat=26
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
The bobby flay blender leaks out the bottom where the blade is screwed in
Take it apart and pit the gasket on the other side of the cutter assembly.
Top Blenders Experts
Mike Cairns
Mike Cairns
john h
ADMIN Andrew
ADMIN Andrew
Are you a Blender Expert? Answer questions, earn points and help others
