20 Most Recent Waring MBB518 2Speed Blender Questions & Answers
follow this steps . God bless you
  1. Unplug the blender and remove the jar. Undo the screws securing the baseplate. Separate the baseplate and attached motor collar from the base housing.
  2. To remove the switch housing, remove the decorative facing to get at the top screws. Remove the lower screws from inside the blender base.
  3. Hold the fan to keep the motor shaft from turning as you unscrew the drive stud. Remove the shield and any washers. Unscrew the fan nut to remove the fan.
  4. Disengage the strain-relief fitting from the housing. Remove the wire connector joining the power cord and the lead to the brush housing.
  5. Label and disconnect the lead wires from the switch block. Remove the motor mounting bolts and lift out the motor if necessary.
  6. To free brushes, remove the leads attached to the brush housing. Use a screwdriver to press lead terminal through the slot in housing. The brush spring may pop out (don't lose it!).
Waring MBB518... | Answered on Nov 24, 2013
Go to the following link and locate your blender's model type: http://www.waringcommercialproducts.com/product-documents.php?type=parts
Hello, Carla -
For all electric blenders the rubber gasket is placed between the glass or plastic blender container and the rotor with the blades.
The assembly is easy to recall when one realizes the rubber gasket is the seal for keeping liquids leaking out of the blender.
See the image here (it's for a Black and Decker, but the assembly is the same):
http://stainless-steel.us/12-pictures-of-baby-bullet-blender-instructions/black-and-decker-blender-assembly-instructions/
The image here shows the assembly for a Waring blender (different model than yours):
https://www.etundra.com/restaurant-parts/parts-diagrams/waring-bb140-bb150-bb240-bb250-bar-blender-parts/
Best wishes.
Waring Blenders | Answered on Jun 02, 2018
Dear Katie,
If your machine has a belt inside, it is probably bad.
However, most do not.
I am suspecting you have a bad bearing inside the machine, and the burning smell is wires; in the which case, please do not use this machine again until it is repaired, so you do not experience a fire.
God bless your efforts,.
Waring Blenders | Answered on May 25, 2018
Fixya is unable to identify Waring blade sources.
Waring Blenders | Answered on Feb 28, 2018
Waring MBB518 2Speed Blender Logo
Popular Tags
10 questions posted
Top Waring Blenders Experts
Darial Jr Lasaria
Darial Jr Lasaria
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
View Most Popular
Waring Blenders
  • Waring Blenders
Most Popular Question
anyone schematic showing put motor back
  • Blenders
