Temps dropped during nite pressed down on drivers side and it slipped off track motors is fine
Usually this is the nylon gears that control the cable. They are not individually replaceable. You have to order the whole internal window mechanism. The are not cheap. To get to it is a chore, there is a special tool that you need to pull the door panels off. If you don't use the tool you will damage the nylon clips or the door panel. When you get the panel off, you need to remove the sound deadening material and that is a stick mess.
If your window has popped out of its track , a neet hack to get it back in is to use a bar of soap !! just rub a generous amount on glass edge and window track and gently wiggle the glass back into track (don't bend glass) use only an old credit card or your "cold" bare fingers to wiggle it back in , metal tools will break the glass 4 sure
leave the soap on windows edge it keeps ice from sticking !!
