If the air blows out of all of your other vents then you have either had an actuator go bad which controls which ducts the air flows through, or the shaft that has the "flap" on it has popped loose and no longer moves which will only allow air to go to the vents that are not locked. The easiest way to find out would be to get under the dash and start at the fan and trace air flow til you find the problem.
the blower relay switch controls the blower motor,this sounds more like an air blend switch on the heater control head on the dash,not making the switch over in that switch.it could be the air blend door motor on the heater duct under the dash on the passenger side.this can be checked with a scan tool that has the capability to communicate with the bcm computer on this car.
either your blower motor went bad or the blower motor resistor. what you can do is pull the plug from the blower motor and hook direct power from the battery and a ground, if the blower works replace the resistor the resistor will be mounted to the heater box close to the blower motor .follow the wires from the blower to the resistor. hope this helps
