SOURCE: No picture and no power LED
Hello. I have the exact same tv. and the same thing happened to me! What i did was buy a expensive Surge Protector and now it works! I hope this info is useful!
SOURCE: No power, red led doesn't light. Power cord is
Manufactureres usually keep their schematics to themselves however you may be able to contact them to purchase a new power supply.
SOURCE: 47" two yr old Visio
This is the second time I have seen this problem this week. Seems like a common issue on Vizio LCDs. Anyways the problem you mentioned indicates that the tv-micro IC has failed. THis is located on the main audo/video board and a component level repair is not possible in this case. The main A/V board has to be replaced and it should cost you around 100-125$. Would you like to do it yourself?
SOURCE: I have a olevia model 232-s12 tv has sound but no
Good day.
If you already replaced a new inverter board and T-con board and the problem is still there.Try to play the video on the DVD,if the video is OK check the cable connection and try to run auto scan.
If the problem is still there check the input supply of the system board or main board it should have 5vdc and 12vdc,if it is OK replace the system board.
Review this manual page 4-1 abnormal display http://www.scribd.com/doc/36875894/Olevia-232-S12-SM
I hope this solution will be helpful.Thank you for using FixYa.
SOURCE: lg lcd can a bad tcon board kill all power
Yes , it can be a short on the board that will ask the SMPS unit to protect the power so as to switch off. So even with a multi-meter check you will be able to trace the short on the board, the drivers or any capacitor that is cutting off the power which must solve the issue.
All strips on that side went out
