Singer Sewing Machine 9217 Logo
C
Cate fortune silkovich Posted on Nov 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the instructions for threading a singer concerto sewing machine model #9217
R.A. Ellis
Level 3:
  • Singer Master 12,731 Answers
  • Posted on Nov 09, 2016
R.A. Ellis
Singer Master
Level 3:
Answers
12731
Questions
Helped
2619424
Points
59176
The manual would probably be helpful:
SINGER 9217 manuals
How do you install a bobbin case on a 9217 Singer sewing machine
Manual at, page 10
https://www.manualslib.com/manual/1054096/Singer-9224.html?page=10#manual
Hi My hand wheel on my Singer 9217 is very stiff how can I get inside to see if there are threads in there
If, you go on www.youtube.com and ask how to remove the cover on a Singer sewing machine, they show you step by step and best of all it is free. Good luck.
Singer model 9217 schematics
You can probably by the service manual from Sewing Parts Online, but as I explained in your other post, you really don't need it.
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Threading problem
Hai, you check the bobbin tension.
Singer model 9217 too much bobbin tension
First recheck your upper threading. Then go to Pinterest.com and do a search-there is a read good explanation on adjusting the bobbin case.
24helpful
2answers
Singer Concerto 9217 - problem threading bobbin
thread the same way as for sewing. put empty bobbin case in bottom. close slide plate only to red button, not all the way. wrap thread from needle around bolt that holds on the presser foot (or just hold it tight). press pedal to sew. bobbin should wind. when done, shut slide plate all the way and sew.
if this doesn't work, try using a pin to push down the center of the bobbin when the slide plate is in winding position - the little catch on the bottom of the plate breaks easily and then the bobbin won't wind without a little help.
5answers
Instruction Manual for Singer Concerto 3 sewing machine
i have this machine and would be glad to answer any questions for you
susan
3helpful
2answers
Singer Concerto sewing machine model 9217
i was having the same problem. try putting in a new slide plate - the pressure from it holds the bobbin down, but it wears thin after a while. fixed mine.
Singer Concerto sewing machine model 9217 - bobbin thread problem
This problem is common in sewing machines with plastic bobbin cases. The new case you've ordered will most likely solve your problems. I might suggest checking the point of the rotating hook, to be sure it is burr free.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
