Ovens Logo
Anonymous Posted on Jul 19, 2009
I have a Thermatronic II Micro-Thermal Oven, Model CMT21. The microwave is not working. Is it repairable and at what cost?
  • Anonymous Jul 21, 2009
    Info was just what I was looking for, and convinces me that it does not pay to repair it.
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on Jul 19, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2972637
Points
24702
HI, This unit is repairable but, these parts are very hard to find and, they are expensive as well. i will list all the parts needed below and, the total parts price as well.(This is basically a power sector issue. power board failuer).
Parts Needed For repair.
1 Transformer- $202.95 part number 487123 -(Is available at this time)
2. Capacitor- $35.65 part number 412712-(Availability is Questionable)
3. Diode- $35.80 part number 412674-(Availability is Questionable)
These are the necessary parts needed to restore your unit. the hard part is actually locating the Capacitor and diode. these parts have been discontinued at this time but, there may be some compatible parts that may work. this is a long shot but, worth the try.
Total price cost will be around $274.40.
1helpful
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Require instruction manual for Thermatronic II double oven.
Here is a contact number for sears. (800) 252-1698 Maybe they can help you find one. Good luck
Model KEMS308sss microwave not heating - light comes on, turntable works but no heating. Unit is 4 months old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Reassembling thermador Thermatronic II lower oven door cmt21
you can use some of the glass of the old oven just need the size of the glass if you order from the manufacturing it very exp
Thermador Thermatronic II Latch Release issue
If you look at the top row of controls, you'll see one that says "Latch" with a switch to toggle between Locked and Release. Push on the "Release" switch setting and try the latch. It should release.
Oct 22, 2009 • Ovens
The lower oven in my CMT 21 Thermatronic II oven will not heat properly. I set the temp. at 350 and it will only heat at 250 as an example.
if it is not turning red, the element needs replacing. if it is turning red, thermostat or control panel issue
Jul 22, 2009 • Ovens
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 • Ovens
Top Thermador Ovens Experts
ZJ Limited
ZJ Limited
vince
john h
Are you a Thermador Oven Expert? Answer questions, earn points and help others
