What is the advantage of using firewall? I have some problem with firewall that when i ''ON'' it my internet connection disconnet autometically and my computer restart within 30 seconds. Another question is that can i stop process of ''shutdown -s -t 30''?
If you are behind a router firewall is allmost 0. Firewall just blocks applications to connect to internet and also blocks incomming connections.Firewall has a list with allowed applications and the otherones are blocked. So for home use you can disable it. to abort the shutdown you can use : "shutdown -a"
if your ps3 constantly disconnects from the internet all you have to do is following the instructions below:
1)Go to internet connection settings
2)Reset your ip adress
3)press internet cnnection test
4)restart the system 5)your problem is gone
The speed of the internet the cable is faster than a wireless connection, the only advantage of wireless is that you don't have to run a cable to the computer to get internet.
Hope it helps!
The greedy folks at Microsoft use their WGA (Windows Genuine Advantage) to monitor your microsoft products, cant be helped, they claim to only check microsoft products though this should only take a second or two for verification. Check your firewall settings and if neccessary use multiple firewalls to stop the intrusions.
I purchased linksys WRT54G when I connect the second wiring I
lose my internet. My wireless use to work but since I disconneted it and reconnected the wireless does not work.
Device communication issue! This sometimes occurs fro many reasons mainly FIREWALLS~ In order to keep this from happeninig you should probably setup a static address on your laptop or if your network has a SSID, it needs to be manually set into your adapter because it is not picking up your network. This often happens when you use your laptop in or on other networks. Easy fix, but need answers to these questions!
