Irons Logo
F
Freda Posted on Oct 20, 2016
Hi how can I open my morph Richard steam ganirator iron becase I can't open the screw at button of the iron
How do i open screws
broken studs for screw tightning,cant repair without expert,there is one screw under main wire side,second is under pressure knobs to open it
How to release the stuck steam button stuck in the up position in a morphy richard
On this model i believe you have to slide the button back to release perminent steam function. I am not sure what screws are on this iron as to what they are called.
regards, I hope this was useful.
May 13, 2014 • Irons
Descale
Soak and/or run vinegar or CLR through it. They also make a steam iron cleaner.
Tefal protect concept steam button not working
hi! Long time listner, first time caller.
Iron not steaming AT ALL.
I have a tefal gv 7096
It turned on, all lights working and i can hear it heating up and when opening the calcium deposit i can see steam.
When i pressed the button - nothing. The iron it's self is hot (the plate) the lights on and but no steam.
The cord connecting the iron to the steam was also cold, so i could tell no steam was getting to the iron at all.
I wasn't sure if it was the button not working or something clogging the cord to the iron.
I did the vinegar thing. Let it sit for sometime (40 mins) and still nothing.
I did a weird thing of very carefully putting water on the plate while hot and it created steam from the plate. i think some backflowed and it started steaming, within seconds. might have happened with a bit more time anyway, but it def helped. All wokring fine now :)
Aug 10, 2012 • Irons
1helpful
3answers
Steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Steam generator iron beebs when button pressed but no steam green flashing light on aswel
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
2helpful
2answers
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
B & D Light and Easy Steam/Regular Iron
if you have a multimeter and know how to use it get that tool ! if not , buy another one.
Top Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Iron Expert? Answer questions, earn points and help others
