Do you need to convert Numbers document to an Excel document How about vice versa If you don know how this how to is the one for you Open the numbers document on your Apple Mac...
Open the file with .xlsx extension. Press Ctrl+S or choose Save as option from the menu, then Save as dialogue box will appear, type a new file name or ignore it, choose "Excel 97-2003 workbook(*.xls)" from the 'Save as type' menu.
SDF file is a compact relational database also called a SQL server database. Designed for the application that runs on mobile devices and desktop.
If you only want to access SDF files in Excel sheets then you can see your SDF files in SQL Server or Visual Studio.
yes it can.. just download xls to pdf file converter.. it can convert xls, doc files to pdf file. Or you can simply convert it using the internet. just type to any search engine this keyword "xls to pdf convert"
hello my friend, the error refers to the writing of xls to xml of the file. So therefore the error committed within the software side particularly in the excel software. Try to convert another xls file to xml files then if you find same problem i advice you to used full version of office rather than using light version. Then reinstall the office particularly the excel software
I have not worked with XML at all, but you say you have Office 2007. I just created a spreadsheet in Excel 2007 and then I saved it by File>SaveAs>XML Spreadsheet. Have you tried that?
When you choose to open the csv file - A pop up box will take you through the steps - You need to highlight the seperators as Excel is currently unable to do this.
Once you are going through the process you will be able to select, hash, space, comma as the seperataor into the respective columns.
